20" Rankin/Apex Disc Sander
vance hough
I am considering buying a used 20" Apex disc sander. Any thoughts on the quality of this sander?
vance hough
Re: 20" Rankin/Apex Disc Sander
Henry Higginbotham
I've never actually seen one of these, so factor that in. I did find one on YouTube and see that it's a US-made machine, probably 50 years old or so, and looks well-made.
Disc sanders are relatively simple machines. Just check it: If the disc revolves with no noticeable runout, the motor comes up to speed without fanfare or bearing noise, the table moves well through its intended range, and there are no welded repairs (or at least no poorly done ones), then it's probably a good machine.
I have an ancient 15" Porter Cable D-1 and can say that big, solid disc sanders are very useful machines.
Robin Corell in Atascadero CA
I would not put them in the same class as the old Max, State, Master, or Oliver disc sanders, but they are a step up from the Enco and newer Powermatic/jet/china clone disc sanders which use the same patterns or stylings.
The old early/mid 60's apex sanders with the reversible motors are a decent sander that will most likely be the best sander you are likely to use. My reasons for not likening them as well as the other brands I listed are due to some features that make the other sanders more suitable for the precision demands of patternmaking. Overall they are a heavy duty industrial sander and most wood workers would be thrilled to own one.
The motors are rebuild able and that is the route you should take rather than replacing the motor with something else. Also you should never remove the disc from the hub, they are dynamically balanced as a unit.
I have no idea of value or what would be a good deal but if it is an older machine it is definitely a step up in quality from the new 20" sanders and should be valued accordingly.
Robin
Re: It has to be better than my Laguna.
