Need mantle clock idea
Bill Tindall
I need a clock to sit upon the mantle of family room. The traditional kind are a bit too formal for the environment. Creative design is not something I am good at. Anyone have any designs to offer?
Re: Need mantle clock idea
roger lance
I just did a search on "mantle clocks" on Yahoo and got numerous sites with an abundance of pictures/styles of clocks.
Bob
Bob
Depends on the decor. Arts & Grafts, Rustic, Green & Green, whimsical ???
Pete in Holland, MI
Look up Klockit. They have kits to buy, but their catalog has lots of ideas.
Not sure on your skill level. That will help with us helping you.
Pete
Joseph Mulherin, sr
Hi, Bill, several years ago I made 19 mantle clocks for Xmas presents to family members and friends
Baqsically it was a 1/2" plywood box 18" high x 4.5"deep x 12" wide with the open back to which some 1/4"
paneling on. In the upper portion of the rear was a 5 x 6" hole/door thru which you could go in and adjust the time and add the battery. The door cutout had some edging which you added to allow the door panel to be reinserted and be closed. The upper and lower bases of the clock were just pine boards which extended out about 2" from each edge allowing some moldings to be added. The door was just a framed glass. The sides of the cabinet in front had boughten pilasters I got from HD and cut in half with my band saw and glued and nailed to the cabinet.
Inside was the electronic clock movements I got from Klockit. Saw my haircut lady a few weeks ago and she still has her two clocks...one of which I made with a reverse face so customers could see the time in the mirror.
Took me three months to finish and they were enjoyed to receive.
Yonak
Bill, I got a germ of an idea you may wish to work on, if it suits you. Kind of a stylized Oriental motif with a barrel inside a frame :
It needs a base, likely supporting the barrel. Like I say, just a thought . . .
Dusting it may be a pita.
Good luck with your project.
now there is some creativity
Bill Tindall
Not fond of oriental but the idea of a stick frame around a circle could be adapted. This is an idea I can work on.
Tony - Memphis
I would look at KlockKit for ideas. A lot of their stuff is pretty tacky, but some of it is ok. Might at least get you started. Woodsmith had some nice designs for mantel clocks over the years. I built this a few years ago as a Christmas gift for some close friends. Not my style, but I enjoyed the project. I did my own design, but was inspired by clocks a Schlabaugh and Sons.
Tony
Handsome clock
Bill Tindall
Everything aobut it seems perfect- color, texture, proportions.
Kneale Brownson
Re: now there is some creativity
Kneale Brownson
Two frames with a barrel holding the clock movement would give you a base too.
David Barnett
Less formal tradtional
Ohhh, I like that one
Bill Tindall
but it needs numbers. Can't abide a clock without numbers.
Re: Ohhh, I like that one
Joseph Mulherin, sr
Bill, you can buy all sort of faces from Klockit.
John McGaw (Bodger)
That design is so stripped-to-the-bone that I don't imagine numbers would work visually on it. One might get away with minimal marks at the hour points but even then keeping them from overwhelming the design would be difficult.
numbers
Jerry Gibbs
I made an arts and crafts clock from a picture. The numeral font was identified as Dard Hunter by a member of WC. I could not buy such numbers. I copied font I found somewhere on the internet and made the numbers the right size. I cut them out of sheet aluminum with a jewlers saw, painted them black and stuck them on with carpet tape. Jerry
that is an idea to consider
Bill Tindall
not sure how good I am with a saw though. Good to know it can be done.
