heat gun usage on glue?
Joseph Mulherin, sr
Since I found a flat on my rockers, I am asking if anyone can advise on using my heat gun to soften the glue and rebend the laminations to the proper curve?
Joseph Mulherin, sr
Re: heat gun usage on glue?
Sorry to hear about your flats. I would really not recommend using a heat gun or anything else to take apart glue laminations. You've got a lot of area to separate and then re-glue. Not the sort of thing that can easily be separated or thoroughly separated.
Can you reshape them by other means? I usually do my rockers out of solid wood. Typically I draw my lines, saw the curve with a band saw and then clean up the curve with a low angle block plane and a spoke shave.
If you have a low angle spoke shave, you might be able to correct the flat.
Joseph Mulherin, sr
Thank you, JL, that is exactly what I have already decided to do....remake the rockers from solid material. Just had the thought and had to ask. And like I said earlier...no Xmas presents this year, but Valentines day is coming soon.
in the future
Jerry Gibbs
would it be practical to make the outer layer thicker to allow for corrections?
Bob
I think you would be better off to just make new ones.
Joseph Mulherin, sr
Just tried something....measured the flat on the rocker, 4.5", cut kerfs 1/4" apart,
opened up as much as I could and smeared glue into the cuts. Then laid on table and
took two pipe clamps and squeezed the cuts closed. Laid my metal ruler along side and the curvature does match what I think it should have been.... anyway, it looks good for an experiment and I shall let you guys know how it turns out. If it works I have saved the rockers.
Figured up how much money I would have to spend to remake them and it is considerable
Joseph Mulherin, sr
It worked!! rocked the rockers and there is no more flat...yea! Band saw kerfs are noticible but a little sanding and they will disappear when finished with color. Am joyed...saved many days work and saved the rockers for the three chairs
Re: new rockers for chair
Joseph Mulherin, sr
Installed the third chair rockers and sat in the chair....the one rocker snapped in two....so I took both off and bought some more oak and am in the process of making two new rockers....and I am making sure they are properly aligned before applying pressure with clamps. All have to do now is install the new rockers, do some edge routing and some sanding on some joints and surface marks, then finish with the Honey Amber stain, and maybe cover all with a shellac. MIGHT be ready for Xmas after all
Joseph Mulherin, sr
Tested on the applying shellac and honey amber to a scrap piece of wood to see which way would be best.
Seems applying the shellac first, sanding the fuzz off by hand, then applying the color stain will be the best result.
Comments please on a different outlook and suggestions....please....thank you
Finishing
Merle
Joe, I think it is very common procedure to apply a wash coat (maybe 1#), scuff sand, apply stain and then the clear coat. Maybe some others will chime in.
Re: Finishing
Joseph Mulherin, sr
Thank you, Merle, I viewed some videos and articles that said exactly that thought.
I am having a time with the rockers on two chairs....seems they still have a flat spot, so shall remake them out of solid material and present them around valentines day to the granddaughters. The other chair is almost ready to coat with the shellac and honey amber....should be ready to present to my female doctor before Xmas....a very nice lady too.
Re: Finishing
Joseph Mulherin, sr
Alder does blotch alot unless sealed with a washciat first of a sealer. So, I am going to thin out the shellac and make it the washcoat, scruff sand it then apply the honey amber with some cotton wadding balls like they use for waxing. That way I can control much better the amount of color which is applied. More can be added if I do not like the first coating. Chair is almost ready to do this event....should be finished this week.
Other chairs are on hold until next month.
Re: Finishing
Joseph Mulherin, sr
OK, I applied the shellac, waited three hrs, then applied the honey amber stain....came out like I was just adding paint to the chair....NOT SATISFIED at all with finishing!!!!. So, I am thinking I shall put on another coat of paint undercoating and then spray on a gloss color of something.
I can work the wood, but the finishing never comes out as I wish. NUTS!!!
Why di I even try to do anything like this project????
Re: Finishing
Joseph Mulherin, sr
Read an article yesterday ...the guy said to forget about trying to get a good gloss finish on wood using the present day finishes offered....look into the automotive paints and you will get that gloss without having the scars show up. In other words....treat the wood just like a car to be painted...fill in the spots with a woodfiller or Bondo and then the sand and use the red or gray pre-paint undercoat and then use your color over all that and you will get your desired high gloss finish.
Re: Finishing
Joseph Mulherin, sr
Wiped down the chair of the honey amber stain with mineral spirits...which did not dry at all.
Am thinking I shall just paint these three chairs...mostly to coverup some joint marks.
Finishing is NOT my work....probably should farm it out after i do the wood working.
Still, the chair does look presentable as it is now....like one seem in say Apalatchia of years ago...rustic, but strong and serviceable.
Re: Finishing
Joseph Mulherin, sr
Bought some Rustoleum primer and touched up the spots nicely. Am going to spray the wood chair with a gloss Black lacquer.
Re: Finishing
Joseph Mulherin
Well I used the Rustoleum to spray the joints to cover them better of some flaws; then sprayed the Black lacquer today.....I believe i ruined the chair by doing this....so am going to repaint using an enamel white , and keep the chair for myself. Will be giving the doctor the chair I made earlier in the year which is better looking and sits and rocks very nice. Still have the other two chairs which I have to remake the rockers again, but shall try to make better sanding techniques to rid of the noticable joints marks.
Am thinking I shall not try to make any other chairs fo awhile....RA is setting in and Neuropathy in legs and feet which are mostly numb all the time.
Merle
troubles, both physically and with the chairs. It might be time for a nice simple project, just to keep yourself occupied.
Re: Sorry to hear about your
Joseph Mulherin
Thank you, Merle, I put the chair in my Van and am going to deliver it next week you the doctor.
And...you are correct in that I should choose another thing to do and then make only one chair
next year at a time until it is finished before starting another. I have 12 chairs total to make for the family members...3 down and 9 more to do.....where shall I get the time??? and incentive???
Bruce, a MN Galoot
the incentive is its own creature, but the time business is of your making. You very well might find, as I do, that enthusiasm and better time management will return after a rest. You've been working hard against a self-imposed schedule. Take some time for yourself.
Joseph Mulherin, sr
Thank you, Bruce, and you too Merle. I am taking some time to refresh myself and get the incentive back which will lead to getting the time to start again on my chairs for the family members. I do have two more in construction process and just have to recut the rockers and finish. They will be given to my granddaughters in Hemet, Ca and the other one to their mother....also in Hemet.
Yesterday I took the first chair over to my grandson. He was really glad to receive it.
The doctor gave me a call and said it was the "policy" of the medical office she works in that they could not accept anything over $25 value....but the thought was there and swhe thanked me anyway
Larry in nw ohio
Joe Then you need to tell them that is quite a coinsidence, the chair, if I would sell it, would cost just $24.99. Larry
Joseph Mulherin, sr
OK, am making a decision to rework the old rockers. The flat spots were close to the front, so if I reverse them the flat spot will not make any difference and the chairs will rock smoothly. Just have to band saw off the lamination added blocks the had the curvatures on them, smooth out the marks...if any, sand them smooth, the reverse the rockers and reinstall the blocks and install on the legs of the chairs.....should work fine....will let you know how it turns out.
Reversed rockers
Joseph Mulherin, sr
It Worked out just fine, and sat in the chair and it does rock as it should....with NO flat spots.
Now, just have to patch up the holes, sand, and finish applying shellac and stain to color.
Finishing is NOT my thing and the previous staining I did on other projects always came out not what I wanted. Guess I just do not know how to do it properly. Read the directions and try to apply them...but something doesn't come out right. Anyway, I saved the rockers.
stained chair
Joseph Mulherin, sr
Today I sanded a little, wiped it down with a tack cloth. Then i mixed up 2 medicine bottles of shellac
and one bottle of honey amber, stirred well and then applied the mixture to the chair with a small bristle brush making sure to follow the grain of the wood. The first coat came out exactly like I wanted, now shall smooth sand a little and apply second coat. The mixture does not allow the stain to penetrate as much as if it were applied by it self....the shellac also allows for a quicker setting, and I found out the wood does not need any rubbing of the stain for removal after applying....set up in about 1/2 hr to touch.
Now, second chair can be attended to to finish, the delivered to my relatives in Hemet, Ca next week.
