Kerfing Pine
Kerfing Pine
Kerfing Pine
Clementine
I'm trying my hand at a bowfront table. The bows are two pieces, each 4"x20." All of the other pieces are white pine, but kerfing the bows is not working so well with pine. 3/4" pine doesn't want to bend very well even with a 1/8" veneer and a solid pine board isn't any better. Any suggestions, or should I go to something else? Thanks.
Re: Kerfing Pine
Re: Kerfing Pine
Robin Corell in Atascadero CA
I've always gotten better results kerf bending by cutting on a bandsaw vs a tabe saw. It requires cutting 2x as many cuts but the cuts are closer and sometimes when kerf bending with tabe sawn kerfs the kerfs will read through as little flat spots.
The trick with kerf bending is to find how deep the kerfs need to be and how far the spacing should be. Try cuttng to within 1/4" - 3/16" of the show face and space your cuts every 3/8" - 1/4" (on a band saw).
Robin
Re: Kerfing Pine
Bricklay it
I'd laminate a brick-laid front and then veneer it with a sawn pine veneer. As Robin said, it is a tricky balance to kerf-bend boards like this.
Re: Kerfing Pine
Re: Kerfing Pine
Richard McComas
KERF-CUT FORMULA
1. Take the Outside Perimeter of the
radius and subtract the Inside
Perimeter. This gives the amount of
frame to be removed.
2. Divide this amount by the thickness
of the saw blade. This gives the
number of saw cuts.
3. Last, divide the Outside Perimeter of
the radius by the number of saw cuts.
This gives the distance between
saw cuts.
