White Cedar and White Pine
Doug Rodley
Anybody ever carve any White Cedar or White pine? And if so how well does it carve?Also do you have a source for either one or both? Thanks
Doug
Re: White Cedar and White Pine
Doug Ridley
Should have said Doug Ridley. I don't even know Doug Rodley much less be him.
Bruce, a MN Galoot
Depending on dimensions, you should be able to get white pine at nearly any lumber yard. A lot of millwork is made from it. White cedar might be another situation. I got some white cedar for a canoe some years ago and my supplier said it was very hard to find.
Pine should carve well. It's soft and takes detail pretty well. Cedar is very soft but I don't know about its ability to carve.
Robin Corell in Atascadero CA
Try sugar pine rather then white pine for carving. it may be harder to find but it will give you better results. Not sure what your needs are for carving but neither of the woods you listed would be my first or second choice for carving.
Robin
John Veerkamp
Doug,
You might like to try Port Orford Cedar. It's not really cedar. It's proper name is Leland Cypress Close grain and relatively soft. I have some I can ship you if you don't need a large amount.
John
Doug Ridley
Thanks all.
Bring your tweezers
Port orford cypress is known as lawsons cypress, leyland is a sterile cross between montery cypress and alaskan yellow cedar(which is a cypress).
I've carved some Port orford cypress and I would not classify it as a good wood for carving. You have to give it plenty or run out and it doesn’t carve cross grain very well. Also your tools need to be razor sharp, if they are slightly dull the fibers crush rather than cut and you will get tear out. It is my all time favorite wood to work with due to the way it smells, pure heaven, just wish it carved better.
If you tell us what you intend to carve we might be able to give you better advice on wood recommendations. For instance bass wood is hard to beat for ease of carving and its ability to take detail, but it doesn’t withstand weather very well, mahogany on the other hand holds up well out doors and carves nearly as well as bass wood.
Robin
