Watched Rough Cut and learned a new.....
roger lance
technique for joining mitered stock using splines cut into the miter at 90 degrees instead of the traditional lenghtways spline. This was for a bench made of 8/4 stock. Tommy used a power router with straight bit and a jig to position the spline slots. This could prove useful one day.....thanks to T-Mac. If anyone also saw this and can illustrate it....please do. Its good to have a ww show on TV from which you can learn.
Re: Watched Rough Cut and learned a new.....
John McGaw (Bodger)
No comprendo. Do you mean that there were visible splines across the corner of the miter rather than buried inside it? If so, this is an old techniques commonly called feathers or feathered spline. I always used to use it for small boxes since it was an easy way to make strong decorative joints with nothing more than a tablesaw. Even better for some uses is to cut slots across the edge using a dovetail router bit which gives the visual effect of dovetailing without the effort (and without the strength). It is also possible, with the tablesaw, to cut the feather slots at an angle for additional decorative effect.
http://www.craftsmanspace.com/knowledge/construction-of-a-miter-joint-reinforced-with-a-feather-spline.html
roger lance
No these splines (5 in number) were buried inside the joint and were not visible on the finished piece.....this technique reminded me of completely blind dovetails (as opposed to half blinds).....If you have not yet googled Thomas J. MacDonald, furniture maker, do so.....this is a very accomplished furniture craftsman and he has a great potential of showing techniques that we have little exposure to....we are only seeing a small part of this guy's knowledge and ability....he's worth watching IMHO.
John McGaw (Bodger)
Oh OK. I understand now. I've done it with a single hidden spline but never had a reason to split it up into multiple pieces. Was this a cross-grain sort of situation? That is the only time I've tried to do multiple tenons -- joining a wide apron to legs for example. I haven't done it for a long time but it was something of a PITA as I recall. That reminds me that I've really got to get back to the shop.
roger lance
The small square sized splines would be with the grain on one board and cross grain on the other.....it was just a different way of using splines to help reinforce a miter joint....I'd probably have used a single spline running down the length of the miter but stopped short of the edges so it would remain hidden.
Why is it so hard...
McKay
Why is it so hard to bring up the episodes? In my area, the only time the show is on is on Sat. afternoon. I am either working or watching baseball.(when it is in season.) It's like TNT. I will watch there show and their advertisements, but I do not want to pay extra for the channel and then have to listen to adver.
Re: Why is it so hard...
james jacomb
The show I watched today was about a veneer top box. While Tommy is certainly very good, i can not understand way he installed the triangles after glueing up the top verses taping up the whole piece first. To each his own, but watch him chisel out and fit, ugh!
For those with limited coverage try public television, most stations carry three channels now and usually on create is one of them, with muliple show times. Oh yea, you might need a regular antenna since it is avaliable through the air.
it's all good!
