OT Plasma Cutter
OT Plasma Cutter
OT Plasma Cutter
Gary Smyth
I can't make up my mind. I'm looking for a plasma cutter. 120v. I expect I'll be using it two or three times a month in support of auto, lawn, electrical work. Nothing over 1/2 inch but mostly 1/4" down to vehicle metal. It will also be used for cutting out pieces to build permanent jigs. That said, I've spent most of my time exploring cutters of Lincoln, Miller, Hobart, Eastwood. In the past month I've read so much and viewed so many videos I no longer have a clue as to if these brands are overkill when compared to other mid range cutters. I'll not consider purchasing anything over $800 and less expensive is better. At the same time I don't want to go so cheap I have to spend heavy amounts of consumable dollars with every use. Even though it won't be in constant use I want it ready, reliable, and capable for at least the next couple of years. I'm asking for suggestions if there are other companies that are worth considering.
Re: OT Plasma Cutter
Robin Corell in Atascadero CA
I think we have a Hypertherm at school, I'll double check tomorrow. It is a 220 model and works beautifully. If you only cut clean metal and keep contact with the torch the tips last a long time, longer than the tip on a mig torch.
Rick L
Re: 1/4" on 120 volt is max...
Rick L
Join a welders forum and go to a local welding sales shop for more hands on. I have a thermadyne 120 volt plasma cutter but can get cleaner cuts from my metal bandsaw, jigsaw or recip saw. Look at www.multipaz.com
I have used a Hypertherm
Gary Smyth
and I agree that they do a great job, but my search has turned up only $1200 as a minimum price. Used and rebuilt hover around that range also. Too much of a champagne budget for me at this time
Dick Coers
I have a small Lincoln, but it runs on 220. Rick is right, only 1/4" for the little units, and even then it's slow! I can't remember the model number, but the smallest one Lincoln sells now says in 1/4" it will cut at 22" per minute. Difficult to drag your hand that slowly in free hand cutting, not so much against a straight edge. Thinner guage is where they shine. It's fun to be able to cut around a wood pattern since they have more localized heat than oxy/acet.
