Question for fireplace users (OT)
larry in nw ohio
What is the best MC for the wood you use in the fireplace. As you know the more the MC the more cresote you put in your chimney. My wood is reading around 15%, is that to much? Thank You. Larry
larry in nw ohio
Re: Question for fireplace users (OT)
Bill Tindall
May sound trite but what is best is the MC of the log at hand. I have burned 2-4 cords/yr of wood in a fireplace for 40 years and never worried about it. Dry wood burns quicker and hotter and that is the only factor I worry about. Stuff as low as 15%? I would build furniture out of it.
Not to worry
We have six fireplaces and a woodstove, and I've never checked the moisture content of my firewood. I can usually tell if it is too wet to burn by the heft of it. I don't burn softwoods, because they really do contribute to creosote buildup. A good hot hardwood fire actually helps to keep your chimney clean. That said, it doesn't hurt to get your chimney cleaned and inspected once in a while, especially if you're experiencing poor draft or other signs of reduced air flow.
Re: Not to worry
larry in nw ohio
Thanks for your info. Larry
Read on
Dale Lenz has started another thread about this above, that I hope will enlighten us all, if you will forgive the pun.
Like the pun!
It's always good...
Jason Roehl in Lafayette, IN
to spark the discussion here.
BTW, I wish we could "fire" you as the Interim Punmaster (because the COALonel would be back!) He flue the coop without our permission, which really put a damper on our draft of puns.
Jason
