Another Arborescent Table in progress *LINK*
Keith Newton
I had a rough week last week. I cut about 1/2" off my right thumb, on the jointer. A lot of the wood on this project is figured maple, which has been a challenge to surface. I was getting a bit of tearout, even with a low cutting angle on the jointer, so I wet the face which solved that problem, but made feeding it over the jointer top harder.
I knew I should stop and wax the top, but only had two short boards to run, so proceeded. I always practice, and stress to others, to never feed in such a way, that if the wood were to disappear, that the effort of my hands would be into the cutter, and I was doing that then.
When I was feeding the wet wood, the traction made it hard to get a steady speed, so it was lurching along. As I neared the end of the board, I was just before reaching for the push-block, when it lunged forward about six inches, with my thumb overhanging the side of the 3/8" x 4" board, and into the blades.
Seven hours of time in ER, before I got into the operating room with a surgeon.
Last time I posted my signature / logo, David Barnett paid me a fine compliment. I posted a pic of the date that I had signed the table, and was wondering if I was going to be able to grip and manipulate that tool in the future. Right now, just holding a pencil between my middle and index fingers, looks more like scribbling, than writing.
A few words about the project. The little table will have a glass top, which will overhang the little branch ends by about 2" all around.
There will be a little desk lamp, which will give the main tree-trunk a suggestion of continuing on up above the glass top. Then the frame which Ben is holding over the backdrop paper, will have shoji paper between the two layers of grid. It will be about 15" above the desk, and is suggest upper branching of the tree. It is on a single track, and can slide to the right across in front of another set of open shelves, which are also joined in this reciprocal grid pattern, in the table top, and shoji.
All of the grid is joined with sliding dovetail joints. To keep this from being too easy, we decided to alter the lengths of each square in the grids, relative to its neighbors.
http://www.flickr.com/photos/7391658@N03/sets/72157631969142114/
