I have an old buckboard. Both axels are bowed upward. On top of the axel there is a peice of wood. It fits the curve of the axel. I would like to find out what kind of wood would be best for this use and is the wood most likely shaped to fit the axel or is it bent to fit?
Could be either bent to fit or shaped depending on who was building it. I've seen both. I've seen white oak or hickory used in the two examples that I've seen - but that can be a regional thing.
White oak makes sense as does hickory. Both are strong, close grained woods. If I were steaming and bending, I'd probably use white oak as it is somewhat easier (IMO). A lot of bent wood parts were made of white oak.
I don't know if you are doing a restoration that needs to follow the original closely, or if you are at liberty to use a substitute wood that might be even denser or better than the original. If so, you might look into some of the denser tropical hardwoods for this. I doubt they would have bent the wood for this, as the curve isn't so extreme that it would create short grain if you just shaped it to the arc in question. Then again, I am guessing. Good question.
Elm also has a history of being used in wagon making, particularly the wheel hubs. There are many different types of elm, but rock elm is probably the most suitable for your project.
Thanks for your interest and input Ellis. This is a display piece in our front yard so I don't want to put too much money into it. I'm going to try to send you a couple of pictures but really don't know how to do it so you may not get them or I may send them in a seperate e-mail. The wood in question runs along the top of eacfh axel and is held together by the steel clamps. The arch in the axel is about 2" in 4'.
