MS word problem/frustration
Chuck in Mtl.
I am placing some objects in a word template like rectangles that will hold data and how to get them to be exactly in the position that i want is difficult. The rectangles seem to want to move because something is pushing them out of the way. Is there an easy way to make a template in word?
Re: MS word problem/frustration
Sgian Dubh
That is one of the big frustrations about MS Word. I've never found a way to place images in a document and make them stable, in the sense that they stay exactly where you place them. If you have four or five images on one page they slide all over the place, even on to adjacent pages.
My solution is to use MS Word for creating the text in isolation along with all the other elements you might need in a document, such as Cover Page, Table of Contents, List of Figures, Index, Glossary, Bibliography, Headings to 5 or 6, Captions, Figure Descriptors, Paragraph and 'Normal' font formatting, etc. Word has very powerful tools for all those processes, and it's all controlled by the Formatting options available in the 'Styles' section of more recent versions of the programme. Stage two is to transfer all the text in to a programme that handles images and text well. Adobe's InDesign is one, but that tends to come with Adobe's Creative Suite including PhotoShop. Failing that you probably have MS Publisher in with the suite of MS programmes, and this can be used to place your images where you want them, and you can transfer the text from Word to Publisher simply by highlighting, copying and pasting. Follow this up by setting up how you want the text to flow around your images. Slainte.
Stephen Kirk
There's a couple of tricks that can help you do this. If you can break the page into areas, then add a table to the page with enough cells to equal the areas. Then you size the tables cells to be where you need them. Finally you place your other objects in the cells. Within the cells your can control alignment, spacing,etc.
Another thing I've done ist ditch Word. If you have PowerPoint, it is easier to lay out individual objects in. Not sure if PowerPoint would suite your needs if you have other pages with all text and such.
Joanne in Point Pleasant, PA
If you change the text wrapping properties of the object to either "in front of text" or "behind text" you will then be able to move the box or picture around the page.
Chuck in mtl.
I will give powerpoint a try instead of Word.
Dale Stansbery
I've used a program called Publish-iT Pro for years that handles publishing type layouts beautifully. The Pro version costs $36, plus you can create a Pdf output. It's available at www.postersw.com.
My solution is simple but way off the beaten track
Howard in Toronto
Word has its own code issues that can make slightly more exotic formatting a nerve-wracking experience. No question about it.
But I think PowerPoint is an evil, evil program. No rhyme or reason to things that go sliding around to where you didn't want them.
Instead I use Excel.
It's bone-simple. Define the areas for the graphics by choosing the rows and columns - then lay in the type on a line by line basis in the areas YOU decide - you can completely custom-tune the space by setting the row heights and column width - there are a few more formatting than in Word - but it lacks kerning capabilities.
HTH
Howard
Rick Christopherson
Right-Click on the edge (not in middle) of the text box and select "Format text box". Then click on the Layout tab and the "Advanced" button at the bottom.
Set your horizontal and vertical position as absolute relative the the "Page". No matter what text is placed on the page, the boxes will remain in these absolute positions. If the anchor get moved to a new page, the box will move to that page but still remain in the same absolute position relative to the page. If you have a bunch of these boxes, then you would be best off keeping all of the anchors on the same line (paragraph), and don't have any text on the line that you might edit later.
It may be helpful for you to see where these anchors are located, so go to Tools/Options/View and check the "All" check box in the "Formatting marks" section.
Brint in Richmond, VA
You're up against Word's "Text Wrapping" function, which is really handy for folks who have discovered how to use it, and really frustrating for those who haven't. It's not well marked. :\
Right-click on the object you're trying to place, and bring up the context menu. Click on "Wrap text," and that should bring you to another dialogue with various options. Take a moment to look at them all. My default option is to use the "in front of text" option, which allows me to locate the object independently of the text, and then arrange my text however I please, with no effect on the object. That said, there are times when I know generally where I want the object, and I choose one of the other options (e.g., "left side only," "right side only") to keep it there as the text flows around it.
Note that this works for text boxes, images, shapes -- most everything that's not text. Hope this helps.
Sgian Dubh
Brint, right clicking on an image in a Word document doesn't bring up a 'Context' menu in my Professional version of MS Office 07. It brings up a box with an option to Format Picture. Which version of Word are you refering to?
I can also go to the Picture Tools ribbon and use those tools to place the picture, but the set places available are frequently inconvenient. I also don't understand why your default choice is for the "in front of text" option as this always results in the text being hidden behind the picture.
To be honest, I've never been able to get any version of MS Word to handle images and other objects satisfactorily. Images, for example, always wander about the page, and even on to adjoining pages. And if there are four or five images on one page, I can never get them to behave as they should, which explains why I always resort to programmes designed to handle images and text satisfactorily, something I truly believe Word is incapable of doing. Slainte.
Re: OT - MS word problem/frustration
Sorry for the confusion, Sgian. After some fiddling myself, I realized that the context menu differs depending on whether you're working in a Word 2007 document (.doc) or a Word 2010 document (.docx).
You're correct, of course, that the W2007 RClick context menu does not show a word-wrapping option.
However, if you click on "Format Picture" in that dialogue, then click the "Layout" tab, and then the "Advanced" tab in the lower right-hand corner of the window, you can access all the Wrap text functions:
If you prefer to use the ribbon, you can also click on the "Format" tab and the "Wrap text" button, which provides a similar dialogue:
Word 2010 is not much different, but enough to be confusing. Right-clicking the image brings up a slightly more robust context menu, from which you can choose the "Wrap Text" function:
And as with Word 2007, you can also click on the Format tab in the ribbon after selecting the image, and choose from among a slightly enhanced selection of tools:
As for defaulting "in front of text," I was not as clear as I should have been. That's the setting I use when placing the image. Once I have it placed exactly where I want it, I then go to Wrap Text and switch the setting to "Tight" (or "Square," or whatever I want for the document), and the words re-arrange themselves accordingly. But the image doesn't move -- it stays where I've put it.
I'll be the first to admit that it's not the most user-friendly solution out there. Both PowerPoint and Publisher are more facile in this regard -- however, they're not as widely familiar formats as Word. And just like, e.g., cutting dovetails, the more often I do it, the less thought it requires and the easier it becomes.
Again, sorry for being less than clear the first time around. Hope this helps --
Brint
Sgian Dubh
Thanks for your further explanation Brint. Those images of drop down menus you included in your response as screen captures (presumably) are all familiar to me. At this point I'm not convinced about the stability of any images I include in the text of a Word document, even after reading and absorbing your method. I'll have to have a further play around with it all to see if it works. I suspect part of the problem for me is that I sometimes need to add three or five images relevant to the text on the page, and that's just too much for the programme to handle. Most of the documents I produce tend to be image heavy.
That explains why for many years I've used other programmes designed for handling both images and text well to create the final version of my documents. This way I am able to use Word and its powerful editing and formatting tools to develop the text in headed sections, headed sub-sections, captions for images, image descriptors, quotation text, bullet points, indices, tables of contents or lists of figures, bibliographies, and so on. Word is an excellent programme for creating academic documents, many of which require this sort of layout, if the programme is used effectively, with the exception (so far in my experience) of being able to properly handle images and the like. Slainte.
