REAL MILK PAINT
Building a small garage!
Charles Jackson III
I am looking at building a 12x20 or 12x24 as my new woodworking shop! I am wondering is better to draw my own blueprints or buy them ready made. I need them to pull building permits.
Re: Building a small garage!
Draw your own
Bruce, a MN Galoot
They're mostly interested in things like stud spacing, materials you plan on using, sample drawing of roof trusses or joists, sheathing, shingles and siding. Oh yeah, the foundation, floor and wall anchors. I built a 12 x 16 storage shed built well enough for a house, and all I submitted was a hand-drawn sheet. Our city building inspectors wanted to talk to me to make sure I knew what I was doing, but that's easy. Throw in a couple corrections to meet code, and you're done. Mine did not need to be a scale drawing.
The inspectors showed up twice, said good job, and called it done.
Re: Draw your own
Charles Jackson III
Looking at using these http://www.behmdesign.com/garage-plans-288-2-12x24.aspx
Robin Corell in Atascadero CA
As some one with a 13x19' shop I would urge you to consider a larger space.
Robin
Bob
Bob
Its going to cost you around $200 to $500 and almost always there will be changes. Do it yourself its not rocket science. Use Google sketch up its free and its easy it took me about 10 hours to learn enough to do a good job. The biggest benefit is the drawing will be to scale and you can get your equipment, benches and cabinets into the locations you want and have a real feel for if the building is the right size and doors and windows are located where you want. You can also produce an accurate materials list to get the cost down to a real number. If you need help sing out. You can even get plans all ready drawn and change them to meet you needs all free. OR buy the pro version for under $500 trust me you will use it regularly.
Re: Draw your own
Joseph Mulherin, sr
Back in 1987 I did the same thing, took to the building dept at the city and they too made only one change.
During construction the Inspector came out and saw what I was doing and asked why I did so and so, told him why and he agreed. I also replace the entire electrical panel....had the elec turned off at 7:30am. ripped out all the old stuff which I reused in my shop, was sitting wiring the panel up when I noticed someone watching me out the corner of my eye, turned and saw it was the elec Inspector....asked how long he had been there and he said 20 minutes, and went over and signed off on the list and said I =knew what I was doing....still had about 2hrs to finish working on the hookups and run wire to my shop panel. Electricity was turned back on at 3:30pm before the wife got off work. We now have a good 200 amp service for our two a/c's and appliances.
Depends on your city
It's a simple structure, and a simple drawing should do it; but some cities get all fussy about drawings adhering to standard industry practice, being full-sized, etc.
Our son's an architectural draftsman, and we submitted full-size drawings for our first few remodels (we're doing a succession, one room at a time). I've got a good relationship with the inspector now (just one, and that only part-time, in our little town), so the last permit application was accompanied by 8-1/2" by 11" drawings, and he was fine with those.
You might ask your city/county what they'd expect in the way of drawings.
"...almost always there will be changes."
The drawings are your first opportunity to establish your relationship with the inspector. Drawings that demonstrate you know what you're doing will make for a better relationship. This doesn't mean they need to be professionally done; just, do your best possible drawings, and pay close attention to what the city says it requires.
Don Orr
When I had my addition to the garage done a few years ago, the building inspector required formal drawings stamped by an engineer before they would issue any permits. This is in a small rural town in a small county. I call them big city wannabees. I'd suggest you talk to your building department 1st. It may save you a lot of time and hassle.
I hope your construction goes well and you enjoy your new shop!
Inspectors
We used to have an inspector like that in our town. I went to him for a preliminary discussion of fitting out the upper room in our (retired from its original function) tankhouse*, and he told me he wanted plans with an engineer's stamp, AND he would send them out for review by a city engineer (for which we'd pay the bill) - all this for a structure 12 feet by 12 feet. I estimated the engineering costs would exceed the materials costs, and gave up. A contractor I knew commented to me at the time that the guy knew almost nothing about structure and structural issues, and required engineering approval of almost everything to cover himself.
Thank goodness our current inspector is so easy to work with.
*Also known as watertowers. The water tank on ours sat atop a flat roof, and the building is seriously overbuilt as just a building.
Frank Grambo
Location was the main problem with my last structure. On a two acre property 40,000 sq.ft. were reserved for future septic use. That really limits and in some cases will kill an outbuilding.
The other thing I found helpful was a site that offered rafter cutting data built on pitch and span data that you inputted. To find the site I just did a simple search for roof rafter data.
Good Luck
You are in NY after all.....
Re: You are in NY after all.....
Charles Jackson III
Thanks guys for it will be next spring or summer before construction can start on the new shop!
Don't I know it !    Sigh...
