Height for Planer Stand
Ralph Lipeles
I need a stand for my Delta 22-540 planer. However, the stands that I see all look a little to low, so I plan to make my own. What is a good height?
Re: Height for Planer Stand
roger lance
Ralph....I also had a need to heighten my planer which I did by placing some plywood sheets between the planer and stand....this was originally done because I was using HTC stock supports for my infeed/outfeed and they would not adjust low enough for the planer on its stand.....since that time, I've built infeed/outfeed tables but kept the plywood spacing.....so I think it is up to you to determine a height that is comfortable/workable for you.
thanks for looking.
Dave Bair, Eaton Rapids, MI
The first time you run some 10"x10' white oak planks, you'll be glad the stand is a little low. For me. that translates to mid-thigh at the highest.
Whatever height is ergonomically comfortable for you.
I typically plane my lumber from rough stock. This means a LOT of planing and switching back and forth between sides. I find my most comfortable height for thick and thin to be about 38".
YMMV of course. Dave brought up a good point. You don't want to have to lift heavier pieces. What height is your table saw or work bench? Are those comfortable heights for you? Do you plan on making infeed and outfeed tables for your planer or do you plan on using your existing ones?
I usually put my planer on my workbench or my table saw extension. I tried it on a lower table but I didn't like it much. I figure on building a cart for it one day - but the round tuit hasn't flipped to that side as of yet.
My planer has a flat top. (its a Dewalt) I made the stand so that the top is the same height as the table on my Bandsaw. Its on wheels and can serve as an support table, either in feed or out feed or off t the side to support something like a large circle. The Planer also feeds at a height that allows lumber to feed in from under my workbench and feed out under the wing of my TS. I have a very small shop and multiple use stuff like this is important. As a side note, my Performax parks under the other wing of the TS. This puts its in feed/out feed at about 16" high. This is too low to be comfortable for heavy pieces and for long periods. The planer feed is closer to 30" high and it is much more comfortable.
Joseph Mulherin, sr
I have the Shopsmith equipment and just measured the stand and the planer table.
Together they are 34" from the floor, but Like Roger sho9wed I am going to make
another stand from some 1"x4" spruce I get at the HD and also get some angle iron and make the rolling cart on three inch locking wheels which should make the planer working table at 38"...just right for me.
