Have a question? Ask Woody!
SawStop Saved a Finger Today....
Brian Gray in Sandusky OH
I haven't been around here a real long time, as I've transitioned from woodworking to machining. Nice to see some old names around here!
Regardless, one of my employees had a SawStop "save" today.....see pic....
Re: SawStop Saved a Finger Today....
Larry in nw ohio
I am very happy to see that it worked the way it is advertized. I glad he is OK. But the way what do you do that you can transition around? Larry in nw ohio
Hi Larry.
//But the way what do you do that you can transition around?//
This is what I'm doing now....
http://edisonpen.com/
I still have most of my woodworking tools, but just don't have as much time, as this has grown into a "real" business, with employees, and everything!!!
Great Save!
Don Orr
Better a bandaid (in the background) than a trip to the ER!
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Wow Brian,
That is indeed a powerful recommendation for the safety aspect of the Saw Stop. I am glad that it served your employee well and that a small cut is all that happened, you are wise to use such a great saw. Well done my friend.
Take care,
Jim
Stuart Johnson
Good save, can you tell us just what he was doing or how the accident occurred?
Cutting acrylic 1" square stock down to around .750"
After pushing the stock through the blade, she reached over the blade with her left hand and caught her finger tip.
Bill Howatt
I think I see two things in this description:
1. She knew better but did one of those silly things like reaching over a blade. This is another case of disproving the "my brain will keep me out of trouble" argument.
2. No blade guard?
Bill
//1. She knew better but did one of those silly things like reaching over a blade. This is another case of disproving the "my brain will keep me out of trouble" argument.//
Yes, she knew better, we're revisiting this rule! But it's a "once bitten twice shy" thing. She will have a lot more respect for the tablesaw now. Thank goodness it was only a nick. Had it not been for the SawStop it could have been really bad.
//2. No blade guard?//
No. When cutting 3/4" square stock the blade guard is difficult to work with. It will block the push stick, making it very tough to get the stock all the way through the blade.
But I'm revisiting the blade guard. Maybe I can re-engineer the push stick so that it will fit through with the blade guard attached.
Thanks
Bill Howatt
Thanks for the comments.
I have an overarm blade guard and when ripping narrow pieces do the following:
1. Put the guard just to the left of the blade - the guard is often not over the blade but it may be possible in some cases to have the blade near the right internal edge of the guard.
2. Put the blade as low as possible since it is exposed.
3. When the fence is brought up to the correct setting a narrow trench will be formed by the guard and the fence. My fence is 2-1/2" high so there would be about 1-1/4" from the top of the fence to the blade in your example.
4. The workpiece is fed through with a shoe type push stick made of 1/2" ply. Featherboards can be used as usual to keep stock against the fence.
Bill
Lee Schierer McKean, PA
Why not make a sled that will push the stock through the cut, allowing a blade guard to be in place and to provide eye protection from the flying acrylic chips.
Lee
Re: SawStop Saved a Finger Today.... *LINK*
Jim Dillon
Brian,
Glad your employee escaped real injury, other than to her pride. Great testimonial for the Sawstop TS.
Anyway, maybe 15 years ago I purchased the HTC Brett-Guard saw guard for my TS and have been very happy with it, especially for ripping narrow pieces while using a 1/4-inch plywood push stick. The design of the guard provides 4-sided coverage of the spinning blade (in the case of narrow stock) while at the same time allowing a narrow push stick to pass between the guard/blade and fence. For regular width stock, the blade is surrounded by a 5-sided box of very thick plastic (polycarbonate ?). What sold me on the design, was, at the time, I remember reading that a school for the blind was using this guard to teach woodworking to the blind! I figured if it could keep blind folk safe, then I stood a chance.
Although I cannot recall seeing the Brett-Guard advertised for years, at least in the one or two mags I get, here is a link to HTC's web site. If it is not sold, then maybe you can jury-rig something similar.
The anti-kick fingers in the Brett-Guard are worthless though and I depend on a Biesemeyer splitter. And, if I were doing narrow stock all the time, I would modify the plastic guard a bit.
Jim
Brett-Guard Saw Guard
Dave Bair, Eaton Rapids, MI
You may be lucky you have Sawstop; One woodworking magazine has an attorney's ad in their back section "Did your table saw fail the hot dog test?" and offering a free consultation for table saw injuries.
Chris Friesen
How about a blade cover (lexan maybe) that is fastened to a piece of wood that clamps into the left hand miter slot like a featherboard?
Brian from Monument
I wonder who employes that attorney. SawStop....
The only way to use a tablesaw is a sawstop?
It is the only way to save a hotdog. Must be the attorneys lines....
Back to a non-sawstop world
Collectively we have hundreds of thousands perhaps even millions of hours of non-sawstop tablesaw work.
With a very few injuries...
Bill Howatt
Yes, many hours worked without a problem but if it happens to you it can be life-changing.
According to stats about 35,000 serious TS injuries per year in the US with an average medical cost of $57,000 per injury.
Bill
William Duffield
No, we've had lots and lots of injuries.
I've met many woodworkers who have had injuries from table saws, but which luckily were not quite serious enough to put an end to their careers or avocations. I also personally know someone who is no longer woodworking because she was seriously injured on a table saw. Several apprentices in the same shop had their training, and thus their cabinetmaking careers terminated due to the same accident when the shop was forced to close. I can't count the number of other woodworkers who are no longer pursuing their dreams because of more serious table saw accidents. If common sense of woodworkers and shop owners and the "good intentions" of the woodworking machinery manufacturers couldn't solve the persistent and pervasive problem, we should be thankful that an inventor who also has the skills of a lawyer decided to commit to trying to solve the problem.
