Router table
Jerrid Edgington
I am wanting to build a router table. What type of wood should I use for the top ?
Router table
Jerrid Edgington
Re: Router table
Bob Entwisle in NJ
My router table top is 2 layers of 3/4" MDF laminated to make it 1-1/2" thick. I edged it with solid maple. covered both top and bottom with Wilsonart (Formica) a for a nice slick surface.
3/4" plywood would be good for the substrate too.
Bob in NJ
Re: Router table
Ralph Lipeles
I used 2' by 4' piece of 3/4" plywood and covered it with white formica.
Ralph Lipeles
Re: Phenolic
Re: Router table
Robin Corell in Atascadero CA
Mine is built into the stock table extension on a jet cabinet saw with a 53" fence. The top is melamine coated particle board with a couple or red oak stringers for support. I cut a rectangular hole and then routed a rabbit to support a phenolic sub base I made out of 1/4" phenolic. I have a shop made fence I use for the router table which allows me to clamp a feather board to the table saw fence which makes the feather board adjustable without having to have some kind of track for it.
Ive been using this exact set up for 14 years. The top is not that critical, what is critical is the suporrt structure under the top. I had to remove the red oak stringers as they came from the factory and true them up but it has held true since then.
Robin
Re: Router table *LINK*
Kneale Brownson
I used Lee Valley's steel router table top, added a gauge slot along the long edge and separate pieces of steel outside that and along one end, all set into a maple framework and then used maple for a fence with a box in the center to hook up a 2.5-inch dust collection hose.
Veritas table top
Doesn't matter much what kind of wood...
John in NM
Just make it thick. I've been using a "temporary" 1/2" baltic birch plywood top for years, and its loud
Once I finally bought a nice lift, I glued support blocks made of 2x material to the bottom and the noise is now much less. The new router motor helped too I'm sure, I had been using a 20 year old Makita plunge router in the table.
MDF makes an excellent top, especially two pieces glued together as others have suggested. MDF is hard and smooth, and stuff will really slide across the top if you wax it.
Re: Ellis designed one
and published it in a magazine when he was the (I believe the Editor). It was a very good plan - I based my table on that plan. My top is laminated - starting at the top it is Formica, 3/4 Baltic birch, 1/4" (or 3/8" can't remember) tempered hardboard, and another layer of 3/4 Baltic birch, glued with Titebond 3, except the Formica - contact cement.
I'm cheap......
I went to a countertop shop and got sink cutouts. They were free...and bowed. Glued two of them together back to back. That balanced the construction and canceled out the bow. While I was at it I incorporated bolts in the edge and bolted it to the wing on my table-saw and to the extension rails for the fence. Then routed in a cut out for the base plate on the router. Lined the cutout with hardwood and put screws into the top edge of that as leveling devices.
I THOUGHT being able to use the TS fence with the router was a genius idea. Not so much. It seems that every time I get it set Just Right, I need to rip something. And a router fence could be very different form a TS fence and I need to make or buy one.
If you find a cabinet or counter top shop that will give you the cutouts, take a few. You may find lots of uses for them.
check in here http://www.routerforums.com/
del schisler
this is a router place that has information on router stuff ect http://www.routerforums.com/ I have been a menber for yrs and their are lot's of well informed router experts their , not saying you won's get good information here
Sink Cutouts
Jerry Nicholson
I made mine from two back-to-back sink cutouts about 17 years ago. I mounted it on a frame from an old dishwasher (dishwasher's don't have external frames like that anymore) and used a Freud 15 amp plunge router with the springs removed. It still works just fine and I just don't understand the $300/$400 router tables I see for sale in the catalogs. I built up the fence from the same sink cutout material.
Jerry
Re: check in here http://www.routerforums.com/
Jerrid Edgington
Thank you all for your input.
Re: Router table
Bob
Here is mine.
