A friend of mine is devoted to his very old Shopsmith. He managed to mangle a couple of fingers in it, AGAIN. I am trying to convince him that a SawStop would be cheap in comparison. Does anybody have the contractor version. Even if its a half-a$$ TS it would have to be a lot better than a fifty year old Shopsmith. I don't want to start the political discussion about SawStop, just want to know if it works in the real world.
I don't have one, but with the SawStop name on it... I just gotta assume that the mechanism works. I can't imagine the company that has built it's name (that IS it's name, SawStop!) putting out a product that does not work 'in the real world.' Can you imagine the press if someone had an accident with a SawStop saw?
I still wouldn't deliberately stick my finger into a moving blade, but I will likely buy a SawStop when I can (or whatever else is similiar and available when I make the next TS buying decision).
I believe that most Rockler stores have a floor model that you can see up close. I've never used one but I've read that they are well-built saws, regardless of the blade mechanism.
I don't have one. I know someone who purchased one and I have used his (not to test w/ hot dogs or anything, but actual use).
He got one with the 36" rails. The rail and fence system work quite well. The saw is reasonably powerful (1.75 hp). I'm used to powering through things with my 5 hp cabinet saw - the 1.75 hp motor requires a reasonably sharp blade (probably with a thinner kerf). All in all, I was impressed with the fit and finish. It crosscut nicely and ripped nicely.
Would I buy one? Not for me. If I ever get the funding, I'll buy one for the theatre. I'm happy with my cabinet saw.
That's a rather snarky way to phrase your question, Barry.
I don't own the SawStop Contractor saw, but I've assembled, installed, sold and used several of them. All our customers who have bought them are pleased with the way they work, and none of them have had any complaints. It is a much more competent saw than the old Delta contractor's saw I wore out. It's built better than any other contractor's saw I've seen or used. If one had been available way back when I bought my first table saw, I'd still be happily using it. Alas, when I needed a new saw, the only SawStop that was available was the Industrial model, so that's what I have now. I much prefer it over any other brand, even the new Unisaw, and even if the other brand were equipped with brake technology.
Just like the Professional and Industrial models, if you activate the brake on the Contractor, you just replace the brake and the blade, and the saw works just as well as it did the day you bought it. To put this in perspective, when Steve Gass was developing the braking technology, before he realized he would have to build his own saws from the ground up, he shattered a lot of Delta Unisaw cast iron blade support components. From that, one might deduce that the SawStop contractor saw is built much more sturdily than the old Unisaw was.
SawStop's assembly instructions and procedures are by far the best in the industry.
I would recommend upgrading to the cast iron wings and the T-glide steel fence system, if he can afford them.
I actually like the saw from what I know about it. I think the technology is or should be a game changer in the market. I was just making it clear that my friend will be comparing to an old (model 10??) Shopsmith, so it should compare well. It might be more of a struggle if he had a more modern dedicated TS. Unfortunately he suffers from the "if it was good enough for my Dad, it's good enough for me" syndrome. And he thinks he can't afford a $1750 +/- tool. Doesn't seem to get that it would have saved him a lot more than that on this one incident and this is not his first. I just did not want to start the SawStop war again.
OK, you're forgiven. You've got a real tough job ahead of you. I wish you luck. The old "horse to water" aphorism comes to mind.
Except for freight charges based on distance to the retailer from Oregon, my impression is that everyone sells them for the same price. I would suggest you try to find a local dealer you trust, because I wouldn't bet against his future need for another brake.
It fits easily in the back of a SUV, so you won't need delivery. The retail store where I worked is in Delaware, where there is no sales tax, which could be an advantage if you were close.
Barry, I bought and assembled one for my son in law and was able to use it for a few months. If I didn't already have a nice old Unisaw, I would buy one for myself.
Well built machine. I bought the cast iron wings and the longer fence guides for it.
