scooping out seats using dado blade
Joseph Mulherin, sr
Technique I use...use extension table beyond blade; measure your seat contours and put a board at the end across the extension table clamped down tight; mark center of dado on that board so you can see where you asre going; set dado blade at 3/4" heighth. Forgot...on seat glue a 1/2" block on the outside of the seat, this allows the dado blade to cut shallower than when it gets to the rear of the seat. As you progress with each cut and are ready to do the next adjoining cut just add a 3/4" board next to you fence and proceed with you cut. This cut should be the same as the first...or just a little shorter to fit the contour of the seat rear. And as you get closer to the side just keep adding 3/4" boards both to the sides of the fence and to the end board to maintain the desired outline and not go beyond you seat contour edges.
Am doing three seats today and tomorrow this way and the initial cuts are rather smooth which will not need too much sanding. Then use your grinder with a carbide donut or sanding disc and finish the side contours.
Seat leg cutouts will be done after the scooping.
Go to You Tube and watch Charles Neil do a seat this way....it does work nice.
Re: scooping out seats using dado blade
Joseph Mulherin, sr
Setup the Shopsmith and the metal/plywood extension table this morning; marked out all of the seats with dark ink for contours; set dado blade at 3/4" heighth, glued 1/2" boards on front of seat so the cut a shallower cut than the rear; used 3/4" boards on both side and front to maintain seat contour while cutting dado cuts; did 1/2 seat this afternoon and will finish it and try to do the other two tomorrow and Thursday.
Bob
Bob
Get one of these from king Arther tools and be done with it in about 15 min. I use this on my angle grinder and its really fast.
The important thing
...is to arrive at the destination you wanted and be safe about it. Dado blades create a huge amount of feed resistance compared to a regular saw blade, so you need to be very careful. I'm sure Charles explains that.
Glad to hear you're moving along with your project, Joe.
Re: The important thing/Needs to fit well
Its important that the seats be properly sculpted and that the "topography" be accurate. What you need is a really good pattern. (This is the dangerous part.) Find a young woman with a really great appropriate part. Ask her if you can make very accurate measurements. If she does not kill you, your wife might.
Joseph Mulherin, sr
Yes, Bob, I do have a similar disc...in fact three of them all different, but they do the job.
tried the carbide donut on y first chair and it turned out to be almost a disaster....got gouges where not needed and caused me further work to mend them with wsome epoxy and sawsdust mixture....and it didn't satisfy me at all..
I will use a couple of my discs slowly to avoid the tendency of gouging and then use the ROS to smooth out as best it can. Another thing I found out....using a brown paper bag cut to fit the ros will make the wood come out with a beautiful sheen.....smooth and shiny....almost like using 3000 grit paper.
Have three chairs in the process of work and I do want them to be almost as perfect as I can make them....they are meant to be presents to my family members....and another to my doctor who I found out was also into to woodworking.
Joseph Mulherin, sr
Yes, Ellis, the blade does allow more resistance in cutting, but the end result is a fairly smooth seat bottom which will not require much sanding... and using my sanding discs will make the contour edges of the seat come to life. But, I have done three chairs earlier using Charles method and am familiar with it. Doing the drill method of drilling to various depth was a disaster for me.
Bob
Bob
Joseph I take it you are doing a Sam Maloof rocking chair? When I did my seat I only used it to hog out the bulk of it. The dado set up does give you more control so I would stick with what works for you. Like to see some photos of how its coming.
charles neil scooping out chair seat u tube
del schisler
here is the link http://www.youtube.com/watch?v=g6DaDGE_FJI
Joseph Mulherin, sr
Yes, Bob, I would like to publish some pictures of my work, but I lost the setup a few months ago when I had a computer crash, and Ellis has not sent me the parameters of how to set it up again. If someone could assist me in this I would be most appreciative. Thanks
Joseph Mulherin, sr
Three hours dadoing the three seats...finished....smooth cuts... 4 minor flaws to fill in at rear of seat where dado went too far...my fault....will use some sawdust and epoxy. Now just have to setup the grinder with a sanding disc I have similar to the King Arther one mentioned to me to buy. Have about 3-4 different discs I shall use...then the ROS with 100 grit, then 150, then 200....and shall try that brown paper bag trick I found on American Woodworker in a blog.
Going to rain here tomorrow they say so will wait because I have to do the grinding outside because I do not want the dust in my shop.
It really is a joy to be doing something like these chairs for my relatives.
Keeps me active and healthy instead of just sitting around watching the boob tube Still, have a few medical problems I have to go to the VA on Friday to talk about..... but as the saying goes "Old Guys Rule".
Joseph Mulherin, sr
Thank you, Barry, you are one reason I come to this website. Your comments and questions always bring up such interesting responces. Now, at my age...78...if I asked a young lady to let me take some measurements...I would be arrested....LOL.... and the wife would kill me for sure......LOL
Joseph Mulherin, sr
Bought a new 1/2" blade for my Shopsmith band saw and the cool blocks too. My Shopsmith will not cut the 3" cutouts for the rear legs in the seat, so am going to be using the band saw to cut them. I set up my fence and another block clamped to the table at 3" each way so I get the 3" cuts done. Then have to do some curving of the front of the seat , the cut the front curve at the knee area according to the pattern I received from Hal Taylor. Drew up the pattern on some poster board so I have a hard copy to use again and again.
I do this for all of my projects....going back about 35yrs. After the seat cuts are made I shall apply some sawdust and epoxy to my faulty dado cuts earlier....then do the seat grinding with sanding discs to achieve the contours of the seats. Three chairs are in this construction setup. Then shall start on the dado cuts for the legs to apply to the seats, and apply epoxy when they are situated to my satisfaction of fit.
Next will be cutting the lams for the rockers....need 48 of them and 6 oak lams, and 12 accent lam pieces of poplar for the rockers. ... and lots of glue and time to do all this work.
Joseph Mulherin, sr
Well, I finally scooped out the three seats with the dado blade the other day; then setup the BBHT board I got from Hal Taylor and drilled the seat holes. Yesterday my new 3/4"x1 1/2' slot cutting bit arrived and I cut the seats with it for the legs to attach into. Now just have to setup and use my grinder and sanding disc to smooth out the contours on all seats. Legs and arms are made, just have to setup my sanding drum and smooth out the edges, then use the 3/4" rounfover bit on all edges. Am going to use 5 minute epoxy to set the legs into place and then use some 4" bolts to firmly anchor them in place.
Lots to do this next week or so. Have decided to have thr three chairs ready to present to three family members at Xmas.
Joseph Mulherin, sr
Took the three seats out yesterday to a saw horse table I will use outside...because of all the dust which comes out when grinding. Ground sanded one seat yesterday and another this morning. Still have to mend some flaws I made using some sawdust and epoxy or Titebond glue... color is most important. Am not going to dye these chairs at all...rather use some clear sealer on the wood to show the beauty. Rockers are made for two chairs...just have to glue up and place into forms. All legs are made, arms are molded to shape....need center grinding out yet....after assembly. Want them to be finished for Xmas presents
Joseph Mulherin, sr
Today I finished sanding contours on the third seat. Also mixed up some dust with Titbond2 glue and filled in some spots....and the color is almost perfect to the original wood. Have enough parts worked to assemble at least two chairs, except for the headrests and the back braces....mpre wood will be purchased on the 8th of Nov.
Made a couple mistakes on the working of two front legs....cut the dado 90 deg off from where it should have been, so have to remake them. Seats came out almost perfectly smooth and does sit well....I sat in one on the chair I have in the shop and it does feel good. Now, since I have the rockers ready for gluing up I shall do them next.
Just three weeks since I bought the initial wood purchase and today I am pleased with my progress on the three chairs.....even with the two legs mistakes.
A few days ago, Jim Fox showed his chair and people commented on the wonderful design and looks.
Go back thru the archives to his posting and see what I am doing ....12 chairs are planned....5 large, five mediums, and then the reading chair where the arms are made into seats with back braces to seat two kids for reading to.
Joseph Mulherin, sr
A thought occured to me about finding the best contour for the seats....sit in a moist bed of sand, then rise up gingerly to maintain the contours. Make a poster board pattern of the contours and mark the depths at several areas on those poster boards for future seats.
Now that's a custom fitted seat
Joe, if you're making a chair for one particular person, the sand-contour method would be one way of doing it. Most furniture is made for some given percentage of the population, on the assumption that it is better to fit a variety of shapes and sizes of people more-or-less comfortably than just one or two people perfectly. In the industry, the percentile is actually around 95%. In custom work, it could be much less, and for really specific commissions, you might try to create a highly specific fit, like the way they used to fit ski boots with blow-in resins.
Chairs are fairly unique design problems, because there are so many comfort factors: shape and position of the lumbar support, height from the floor to the seat, width of the seat, angle of the seat and seat back, knee-to-popliteal distance, height of back, height of arms (if any), to name a few, not to mention the function of the chair. Some craftspeople have made a real science of fitting a chair to various users, but they all have to choose the range of shapes and sizes they want to address. It's good that you're thinking of these things as you build your chairs. It is a great learning experience.
Any Deep-Seated ReBUTTal Would be Unfitting
Feeling better, Colonel?
You must be the chairman of the boards. :)
Re: Now that's a custom fitted seat
Joseph Mulherin, sr
Thank you, Ellis, your comments are most appreciative in my endeavors.
Re: A trully custom fit
C. John Hebert
I have the customer bend over so I can get accurate measurements ;-)
Joseph Mulherin, sr
Started gluing up the back braces...need 21 of them for the three chairs. This takes a great deal of patience....wipe on glue with brush, put pieces together and then 4 copies put into the forms to bend until dry. long time for each to hold dry enough to remove and do some more. Then after I buy some more wood in two weeks I shall have to cut the lams for the rockers and do their glue ups....9 lams per rocker.
back braces
Joseph Mulherin, sr
The back braces have been cut, glued up and ready for the contours of the ends where they meet the chair seat and the headrest. Did enough for two chairs today and yesterday. Now shall concentrate on coopering the headrest to make the curvature. Wood is 2" thk, so I am thinking I shall divide it on the band saw to 1" thk for the headrests. Should have enough material for two chairs. Drilling holes in center leaves enough material on the walls for strength.....will see after coopering is done. Bandsaw only lets me cut 6".
Bob
Bob
We may be old but we got to see all the cool bands.
