Router bits
Router bits
Router bits
Jerrid Edgington
I just got a Dewalt 2 1/2 HP router, fixed and plunge base with the 1/4 and 1/2 inch collett. The question I'm having is what type of bits do I get for it (minus the obvious sizes) ?
Jerrid
Re: Router bits
Re: Router bits
AZ in Colorado Springs
When I started out with a router, I picked up a set of 30 bits from a vendor at the woodworking show. The entire set was about $35. They weren't the greatest quality of bits, but I got some experience with the different profiles, and there were stright bits for joinery. Over the intervening years, I've replaced the bits I use more often with better bits. The point is to avoid spending hundreds of dollars on a big set with bits you may never, or seldom, use.
Good luck. And, be careful with that powerful router.
Re: Router bits
Re: Router bits
Dick Coers
What do you make? Hardwoods or soft? Lots of plywood and melamine? Inlays or house remodeling? In other words, buy bits when you need them. For most cuts, stay with 1/2" shanks. Small inlay, hinge mortising, then get 1/4" shank. Prices aren't that much different between them. Heavy use bits, stay with name brands. I like Whiteside or Amana since they are made in the USA. Very seldom use, cheap Chinese can make sense. Get a router table if you make furniture.
Re: Router bits
Re: Router bits
Jerrid Edgington
I'm going to build my first project using cedar to make a head board for my wife.
Re: Router bits
Re: Router bits
Jerrid Edgington
Would this be a good starter bit set ?
http://www.amazon.com/MLCS-8377-15-Piece-Router-Carbide-Tipped/dp/B000FJRN8S/ref=sr_1_1?s=hi&ie=UTF8&qid=1349668705&sr=1-1&keywords=1%2F2+inch+router+bit+sets
Re: Router bits
Re: Router bits
MLCS is a reasonable supplier of inexpensive router bits. They aren't the best, but they aren't the worst.
Personally, I find buying a set to be a mixed blessing. Some of the bits you will really need and use often, others you may never use. If you choose the bits individually, they cost more - but you can get better quality bits (unless you go with MLCS and you get medium quality bits).
The bits I find most useful to me.
Straight bits - you can cut dadoes, rabbets, etc.
Roundover bits - good for putting a rounded edge on various things.
Spiral upcut bits (typically solid carbide and not cheap) - dadoes, mortises, round holes, etc.
Dovetail bits - I've got several sizes - cutting dovetails.
Edge forming bits - ogees, etc. Good for putting more decorative edges on things.
Re: Router bits
Re: Router bits
Larry in nw ohio
Jerrid I stay away from MCLS, unless I`m looking for something that I can not find anyplace else and they would have it, or if I`m going to use a bit very little. They do have free shipping and very fast delivery. Other than that I but Whiteside, Amana, and Liberty. I also use Ridge Carbide tool for sharpening blades, they handle the Liberty Line. The first thing I would build is a good router table. Good Luck Larry
Re: Router bits
Re: Router bits
Mark
I think the best approach, similar to the approach one should try to take with all tool acquisitions , is to buy the best quality you can afford and as said above , buy them as you need them .
This helps you avoid buying stuff you will never use or even worse, buying junk that eventually means you get to but the same tool twice.( experience talking here )
I am not a big fan of sets but as it sounds like you are just starting out, its a safe bet to say you will eventually need a few straight bits and a few sizes of round over or ogees for decorative edging. I would think there would be a few basic sets out there with these combinations that you couldn't get into to much trouble with.
While not a big fan of sets , the one set I have been very happy with was a MLCS rabbet bit set that has interchangeable cutters and bearings allowing for just about any size of rabbet you might need.
I have also been very satisfied with Lee Valley bits in general , but do have some old MLCS bits that are 10 years old and they still perform very well.
Re: Router bits
Re: Router bits
John in NM
I buy bits as needed rather than a set. I mostly use round over bits and pattern bits - the bearing is the same size as the cutting diameter to make a copy of a pattern.
It really depends on how you plan to use the router. If you want to use it for joinery, you will need straight bits in a variety of sizes (depends on the joint). If you want to use it for edge details there are huge numbers of edge bits. Maybe you want to do both.
First thing I would do is decide what you plan to make and let that dictate your bit purchases. For years I only had 3 bits, because I just didn't use the router as often as I do now.
Lots of good vendors, even Home Depot carries Freud bits now. Whiteside and CMT are excellent, and I have a lot of Amana bits, they are great bits as well. Even the house brand from Woodcraft or Lee Valley are fine bits that I use without hesitation. I tend to avoid bits any cheaper than the house brands, I remember one very cheap line that the boss bought when I worked for a shop. One was so out of balance that only one cutter was cutting!
Stick to reputable vendors and brands, and just buy the ones you need when you need them. You'll need any surplus funds for wood -- I'd rather have extra wood than extra bits :D
Re: Router bits
Get a good book about routers
Merle
Jerrid,
Based on this and your previous posts, it seems that you may be somewhat new to woodworking. Therefore, you might benefit from reading a good book about using routers as you are getting to know your new router. I looked in the Departments section of WC and found this review by Barb S. HTH
http://www.woodcentral.com/books/hylton_routernew.shtml
Re: Router bits
Re: Get a good book about routers
Jerrid Edgington
Thank you all for the input. I'm just getting into wood working and seem to have a million questions. Thanks again.
Re: Router bits
One thing that is handy for joinery... *LINK*
John in NM
Is a clamp on straight edge. Tru-grip used to be the only one, but it looks like they are gone now. McFeely's carries what looks like the same thing though. The 50" size should clamp onto a 48" sheet of plywood (my Tru-grip used to do that).
Bora clamp edge
Re: Router bits
Re: Router bits
Jim Dillon
Jerrid,
Congrats on your new router; it should serve you very well for years to come.
You mentioned making a head board from cedar. Do you have a plan or just winging it? If you have a plan, then closely examine the joinery and any edge treatment being used, then buy specific router bits to accomplish the task. This approach might allow you to spend a little more for a "better" bit.
Regardless, you will likely need a round over bit to ease the edges of the wood, and, if you need mortises, probably a straight bit to cut the mortise. The size of the round over bit (1/4, 3/8, 1/2-inch radius) is more a matter of taste and often scaled to the size of the piece and thickness of the wood. The diameter of the straight bit, assuming it is being used to cut mortises, is usually 1/3 of the thickness of the piece of wood. For example, if your head board is made from wood 3/4 inch thick, then a 3/8-inch diameter straight bit would work fine in your plunge base to cut the mortise.
Fortunately, at least in my experience, round over and straight bits are by far my most widely used bits. In fact, I keep a 1/8-inch round over permanently mounted in my small laminate router for easy access. So, here is another option if you want to go with a set of more useful bits. Search Amazon (or other vendors) for round over bit SETS, and/or straight bit sets. You will find a number of options at various price levels. Read the reviews, if available, and go from there.
I have no experience with MLCS bits, but have had good luck with CMT, Freud, Whiteside, and Lee Valley.
Generally, I buy 1/2-inch shank bits, but for 1/4-inch or smaller, I have had no problem with 1/4-inch shanks.
I agree with JL regarding upcut spiral bits. Since I began using them, I have never gone back to my straight-fluted bits. But they are much more expensive. I see MLCS makes a set of those as well.
I second the recommendation for Hylton and Matlack's router book "Woodworking with the Rourter" (or any book by Hylton). Also, despite the hokey title, Hylton's "Router Magic" is great for router jigs, tables, etc. My favorite woodworking power tool book, though not specific to routers, is "Classic Joints with Power Tools" by Yeung Chan, available from Amazon.
One final word regarding budget sets. Years and years ago I purchased a budget set of Forstner bits and brad-point bits never expecting much from them. Well, they are still going strong, although I have acquired more expensive bits from Lee Valley for critical work. Those budget bits were well worth what I paid for them and I have no regrets.
Good luck with that head board, and be sure to wear safety goggles when using your router as your head/eyes are often very close to the spinning bit and bits do break.
I've blabbed on too much. Hope this helps, and keep those questions coming, as well as progress reports/pictures of your project.
Jim
Edit: If you need to use a router bit to cut a mortise, make sure the router bit shank diameter is the SAME as the bit diameter, and try to get as long a bit as possible in order to reach down into the bottom of the mortise. For example, if you are cutting a mortise with a 1/4-inch bit attached to a 1/2-inch shank, your depth will be limited. Spiral cutting bits are usually the same diameter over the entire bit. This (mortise cutting) is kinda the one case when buying 1/2-inch shank bits may not OK (unless you're cutting a 1/2-inch mortise). Hope this is not too confusing.
