Skim (?) cut question ??????
I was watching one of the wood working shows. (If I had one more active brain cell I might be able to name it.) Has to do with one of the magazines. Usually two or three guys and one of them is named Don. Anyway, They were making a small box. Involved cutting a piece at an angle. Piece was about three inches tall and they cut it so that the top was full thickness and the bottom it was about three eighth's. It's like ripping a 2 1/2" or 3" piece of Maple at about a five or ten degree angle. They had what looked like a Powermatic Cabinet saw.
They said that rather than make a single cut and slice off a triangular sliver they would make a "skim" cut. They cut the thickness of the saw blade off, then moved the fence and cut off another saw blade, then moved the fence and cut a third time. So on each cut one side of the blade was exposed.
It seems to me that it would be more accurate and less stress on the blade to slice the sliver off. Has anyone heard of a "skim" cut and are they recommended?
Re: Skim (?) cut question ??????
Can't imagine why...
John in NM
I used to make a similar cut all the time, single pass with the drop piece, so that I could do raised panels with a single pass on the shaper. No reason I can see to do multiple TS cuts, unless one is scared of that drop piece. IMHO, the cut is just as dangerous the way they did it, perhaps more so depending on which side you're on. Repeating the cut ad naseum that way just increases your odds of a mishap.
I do these with a big right angle jig made of Baltic birch ply. Panel gets clamped to the jig and the jig rides against the fence. Large footprint of the jig keeps the panel from tipping into the blade, making for a nice cut.
Me neither.....
I could not think of how to describe the cut, but that is exactly what they were doing. a cut very similar to raising a panel. Their "panel" was only about three Inches high, but what they did was make a carrier or a sled that was a piece of plywood with a "pocket" in it to hold the pieces. They used double stick tape to avoid having to hold such small pieces and install both ends in the carrier and cut both pieces at the same time.
It seemed slightly dangerous to make the cut and why you would want to do it three times rater than one escaped me. I don't know but it seems to me that the blade cutting into the wood with wood on both sides of it is "balanced" and likely to let the blade do the best job it can, but cutting with one side in the day light and one in the wood would be likely to cause the blade to chatter or wander toward the day light.
One reason not to,
Keith Newton
is that any blade cutting through wood, especially tilted has a tendency to cut toward a path of least resistance, so the blade only cutting one side will try to bend or deflect over to the non-cutting side. This will of course tend to heat those teeth on the cutting side more, leading to dulling quicker. And the problem just gets much worse when a blade is dull.
William Duffield
The only reason I can think of is that they were worried about kickback. The offcut has a very sharp edge, and flying around the shop could deliver a very nasty, deep cut.
Still, I assume they had positioned the work and the jig and the fence so that the offcut would naturally fall away from the blade? If the offcut were to be captured between the blade and the fence, it would be very dangerous.
I don't think stress on the blade is a major issue. If you are using your TS to shape cove moldings, you put much higher stresses on the blade.
Dave Bair, Eaton Rapids, MI
Woodsmith? I think they all work for the magazine of the same name. The show is for beginners and usually uses a minimal number of machines. I've noted only good safety practices in the shows I've viewed. The funniest thing is that they never show an actual glue-up for some reason.
roger lance
Does sound like the Woodsmith show.....and I agree with Dave that they specialize in illustrating the basics but in a very safe way.....were these repeated skimming followed by test fittings??.....were they just trying to "sneak up" on a perfect cut??
Pretty sure it was the Woodsmith guys
And no, they were not sneaking up on it, they knew where they wanted to be and they started 3/8" away a took three 1/8" (saw blade thickness) passes. The off cut side was not trapped against the fence either. They could have allowed a small triangular piece to drop off and fall away, but they turned it into saw dust.
