conduit wire pulling trick
Jerry Gibbs
Just used a trick shown me by an electrician. Firmly tie mason line or similiar to a wad of soft cloth that snugly fits inside the conduit. Use a vacuum to pull the wad and string through and go from there. Works slick. Jerry
Re: conduit wire pulling trick
Yep. Known by some folks as a "mouse," for obvious reasons.
The "trick" that took me way too long to learn is the use of pulling lubricant. It's messy, but it makes pulling so much easier.
please explain pulling lubricant
Paul Cates - Henderson, KY
That trick saved me after I laid 150' of 1" conduit down a hill behind my house. I thought I could just shove some stiff wire through, but uh uh. I asked my uncle what to do and he told me about the vacuum method. I said no way but he was right! I used a round foam plug with hooks on each end from the electrical supply store, but I'll try your homemade version next time. I was surprised at how much force it took to pull the plug against the vacuum.
That's a LONG run
I can't recall what the code run is before you come back to the surface to install a pulling box. I think it may be less than that. But it sounds like you got the job done.
Re: That's a LONG run
I agree that's a long run for 12/2 or similar, but I used the conduit to run Cat6 to an antenna for my fixed point wireless internet. Pretty easy to pull that with no wire lube.
This also works ...
Mike Farinella
Take a fender washer, tie a string to it (mason's line), and blow it through the tubing with an air compressor. It worked great on my new shop/garage (~85 ft).
Re: This also works ...
Larry in nw ohio
When I was working on maintanance and I always had to do things differently and ran wire by myself at times, especially in ceiling runs, I would push thru 10 to 20 feet at a time. Then close that end and go another 10 or so feet and push that thru the conduit. I would do that till the end. It would save me running the whole end with fishtape. Also at that time we had to put a pull box every 150 feet. Larry
