Re: Blast gates revisited
Alan in Little Washington (NC)
Bob,
I automated my gates several years ago. In order to do it economically you need to do a lot of scrounging. There are many ways to do it, but I found electro-pneumatic to be best.
The main components are a double acting pneumatic cylinder. These can be pricey retail- I got all mine off Ebay. Bimba is a big name to look for. Unless you want to rig a linkage, the cylinder will need a stroke about an inch longer than the size of the gate and you will need to come up with mount for your blast gate.
Prototype autogate:
Next you need a method to control the (15-20 psi shop) air. I used 24VDC, 5 port, 2 way solenoid air valves from SMC. All came from Ebay. There bajillion different configurations and voltages. Some come as a single and some come in manifolds. You may also want a flow restrictor (right angle fitting with orange ring) to prevent the gate from operating too fast and damaging itself.
Next you need a way to control the solenoid- mine are controlled automatically via small current sensor switches (a toroid coil with internal transistor switch) mounted in box adjacent to every outlet that provides power to a machine with a dust collection need. The sensor detects when the machine is drawing power closes the switch. I used CR Magnetics current sensor switches I got on Ebay.
Here is a link to a (rather long) video/slide show of my system.
