Re: Blast gates
Alan in Little Washington (NC)
Whew! But Mike said he was using Sched 40???
Now as to the blast gates- I believe ClearVue makes gates that fit ASTM 2729. The size of other gates varies by manufacturer.
There are a number of ways to transition a gate to PVC pipe-
If the gate fitting is the same size or larger than ASTM 2729, you can:
(1) use a section of old inner tube (or a neoprene Fernco fitting) and two band clamps as an inexpensive coupling.
(2) carefully heat the end of the pipe with a torch until it just starts to get rubbery, then slip it over the gate.
If the pipe is bigger than the gate-
(1) use technique (1) above.
(2) if the difference in size is small, add a few tape wraps around the gate fitting.
Or you can take some scrap MDF, laminate, pipe coupling cut in half, and a short section of pipe to make your own inexpensive, easy-sliding, tight sealing male-male, male-female, or female-female blast gates (see my article in the June/July 2010, issue #148 of American Woodworker).
Inner Tube coupling:
Shop-made blast gate:
