Have a question? Ask Woody!
When to buy or borrow an air compressor?
I don't have an air compressor. Never really felt the need for one. When I spray, I spray with an HVLP,
There is a stair project in my near future. "Retreading" the stairs and putting on skirting boards. Obviously it would go a lot faster with a nailer and a small compressor. I could get a small nailer (16 gauge, I suppose) and a small compressor.
I have a couple of friends who have small pancakes and nailers and they've said they'd be willing to loan.
I've used brad nailers, finishing nailers, roofing nailers - so I have no problem with their use. I've just never felt the need. I could see the utility of a small compressor (blowing out air filters).
So question - borrow or buy? I could definitely use it for this project. Most of my other work involves other methods of assembly - so I don't know how much I'd use a nailer again. I probably use the compressor.
Re: When to buy or borrow an air compressor?
I never needed one until I bought one *LINK*
Dustmaker Mike
now I have several. The Blue Borg has a Campbell Hausfield with a small nailer I use all the time. It is really lite and easy to carry around. The only down fall if any is the air hose is coiled and sort of a pain to move around.
Nailer
Jerry Gibbs
I purchased a compressor to install a floor many years ago. I can't imagine being without it now. My advice is to buy one and don't get it too small. Jerry
But WHICH Compressor???
John McGaw (Bodger)
I've been in the throes of the same question for years. I can see where having a compressor could be insanely useful but then I think that the money might be put to better use. If I do decide to buy I've been thinking about getting a Makita MAC2400. Does anybody out there have experience with these?
Rick L
Re:Rolaire or Maxus
Rick L
http://www.amazon.com/Rolair-JC10-Super-Gallon-Compressor/dp/B0058NRVMO/ref=sr_1_1?ie=UTF8&qid=1348489928&sr=8-1&keywords=rolair
http://www.nailgundepot.com/Maxus-EX1001-Portable-Electric-Air-Compressor-Details.html
You want quiet get a Rolaire
Light weight...Maxus
Cheap...Harbor Freight, $10 gets an extended 2 year warranty...
I used to repair compressors and these are my choices. The Makita is fine but not as quiet.
William Duffield
I have the Porter-Cable C2002 pancake compressor. It works fine for blowing dust off of furniture and out of machinery, for running brad guns, and inflating tires. It has been very reliable. However, it is loud, so you might want to build a styrofoam box to put around it if it's close to your bench. My bench dog high-tails it for the hinterlands whenever I reach for the air hose or its power switch. I have a Grex random orbital sander and die grinder, and it's not really sufficient to run either one of those for more than a few tens of seconds, so I think I'm eventually going to have to buy a much larger compressor. I'll keep this one too, because it is very portable, and I sometimes need to carry it out to the field to inflate a tractor or cart tire.
Gary Smyth
Eventually buy a compressor. It will sit for long periods, but you will use it more than you think you will. I have a Senco 1 HP portable single tank that quietly handles interior work for brads and 23 guage. There also is a Emglo AM760 2 HP twin tank "portable" (60 lbs) that handles most requirements for air tools like finish nailers and impact wrenches and a Husky H150FWH (pull around like a luggage handle) that is convenient in the garage for keeping tires inflated and blowing air to clean wet grass from the lawn tractor. None were purchased new, none over $80.00. None of these are capable of sustaining spray guns for long term use however. My suggestion is to to get a twin tank 2-3HP for a start, unless you want to spray, and then if that is your application the weight, CFM and price will jump big time. You might be able to rent a compressor for a day and check it out to see if what you rented will do the work you want to do, but do check Craigs list and local Pennnysavers as compressors appear often and you will save a bundle. Pass on any that are unclean (there's a lot of them out there) and make sure that you test to see that the tank pressure at at least 120 lbs holds for ten minutes before you purchase.
+1 on Rolaire
Jesse Cloud
I have the Rolair 210 mentioned above and love it. Its a small compressor, not for spraying or framing, but it is superbly quiet. While its running, you can talk on the phone or have a conversion in my small garage shop without raising your voice.
Like someone said above, you never know how much you need one until you have one. Its great for putting together jigs, shop fixtures, etc. I use it a lot for upholstery staples (chairs). Also great for blowing off sanding dust, inflating tires, and a million other things.
Build a little cart for it so you can conveniently wheel it around the shop and put a little storage in the cart for air tools and a couple of handles to loop hose around. When you don't need it, you can just roll it into a corner and forget about it.
+2 on Rol-Air compressor......
roger lance
mine sits on my assembly table which is only 27" high.....
3rd time . . .
steve mackay
I don't have a compressor but my "rule for tools" is : the third time I have to borrow one, I go buy my own.
Re: +2 on Rol-Air compressor......
roger lance
Jason Waters
I'm not a big borrower of tools, so I'd say buy. I do on occasion borrow a tool however.
I started with a Porter Cable pancake in a kit. My wife got it for me. It had hose and a brad nailer. I was great when we bought our house and I put down tile, and all new baseboard. Earned it's keep right there. Yes they are noisy, but it's not like you will be using it all the time.
Now I would look at a place like CPO outlets for a recon one, sometimes with nailguns, inexpensive.
http://www.cpooutlets.com/shop-our-outlets/shop-our-outlets,default,pg.html
You will find Stanley, Porter Cable, and Hitachi along with other reconditioned nailers there. There are other places as well.
If I were doing it, I would buy a recon kit with a brad nailer and hose (gets you what you need ands seems to be only a little more money for the hose and nailer). Then add an ANGLE 15 ga finish nailer. That's what I have. I do not own a 16 ga. trim nailer. I used the Angle nailer for baseboards and crown and everything else. Yeah, the nails are a little bigger, but it works fine and holds better, and does things the 16 ga can't.
If you do borrow it, if it breaks, fix or replace it (always my worry), and certainly take your friend to a nice dinner or get him a gift card to a tool store.
