Stacked Dado Set?
Stacked Dado Set?
Stacked Dado Set?
I need me a new stacked 8" dado set. I current have the Freud Super Dado set. It is ok but not stellar (IMHO). Might go with the Forrest set but it's been a while since I have shopped around. Anything new out there I should look at or is Forrest still a best bet?
Thanks
T.
Re: Stacked Dado Set?
Jim in Burlington Ont.
SD608
Jim in River Oaks, Ont.
Hi Tommy,
I guess it's about 15 years ago now I bought the Freud SD608. It's been excellent for me, I love being able to creep in on a size with the calibrated dial adjustment.
I cut most of my dado's either with a router or by hand now, I seldom use my TS for any thing more than rip cuts.
Take care,
Jim
Alan in Little Washington (NC)
Two possible issues:
Depending on the length of your saw's arbor, you may not be able to get the full advertised dado width.
Since it expands the trimmer/chipper spacing rather than adding additional chippers, it must "break" the wood ridges between the blades. Depending on the width setting that might result in a less than smooth bottom. I can't say since I don't own one.
On the positive side:
It is much, much better (and safer) than the wobble type dial-a-dado
It can also be used with an INCRA I-BOX.
Sharpening option?
Hoa in Alameda
I would first check with Forrest as how much it costs to sharpen the Freud set. It may be less expensive than buying a new set.
Re: Sharpening option?
Sharpening is an option. I have multiples of my standard saw and miter saw blades. So when I send blades out I have sharpened backup blades. While there are other ways to cut dadoes, it would be nice to have a sharp dado set at all times. So I might buy a set and then send the Freud set to Forrest.
Re: SD608
Larry in nw ohio
Tommy As I usually am I do my dados a little different. I cut the dado edge on both sides and clean it out with a router, That way both edges are a clean cut with the saw blade and if you need it a little wider you can creep up on it with your TS blade, a little at a time.Larry
Re: Freud
Doug Adams
Tom
I have a 8in Freud set that I have hardly used. If you are interested I will send you a picture and we can work out a price.
Doug
dougbali@hotmail.com
William Duffield
If you are cutting more than a trivial number of dados, the Freud Dial-a-Dado can save you a lot of time, especially if you are using plywood that you have no control over its thickness. They come in both 6" and 8" diameters. If you have a 1.75 hp contractor's saw, it doesn't develop enough torque to cut wide, deep dados in hardwoods in one pass with the 8" set. If you are considering a 6" set, but are also considering upgrading to a SawStop, they don't make a brake for a 6" dado.
I don't understand what advantages the Forrest blades get you, compared to the best Freud blades, except maybe the name, and a thinner wallet.
Doug Adams
Tom
I deleted your response by mistake, could you send it again.
Doug
John in NM
I have a Systematic set I got on sale at Woodcraft years ago. It is a fine set for the money, around $100 as I recall, undoubtedly more now though.
