White oak and lignon vitae (SP?)
Went to the mill yesterday to watch them quartersaw my white oak logs. It was an interesting day They use a bandsaw mill capable of sawing stuff over thirty feet long. My logs were about 8' by 40" down to 30". They looked short and fat on the mill. They did not truly quarter saw it the way I thought they would, but they did a good job of maximizing the yield of quarter lumber. The largest log was too big for the saw so they are going to set up their Alaska Mill and cut it in half. (they have a 66" bar for the mill and two huge Stihl power heads for it.) It was an interesting day and what mad it even more interesting was the fact that they are a timber home builder and also the largest supplier of lignon vitae in the country. They had what had to hundreds of thousands of dollars worth of lignon on hand. Racks and racks of waxed perfect blocks waiting to ship. and a shed full of logs. I did not realize that lignon was still in such demand, but they explained the food industry uses a lot of it for bearings. If it sheds a few particles into the food its relatively harmless, not so with metal bearings. We tried to finagle a few small turning blocks out of them, but the owner laughed and said they sell all of it, including the dust to the pharmaceutical industry.
There were also sheds full of interesting wood. Flitches that would make spectacular tables. Sycamore. They also bought the Coney Island boardwalk and are savaging the wood. Think tractor trailer loads of IPE.
I am going to turn the turning club onto the scrap pile.
Re: White oak and lignon vitae (SP?)
It's lignum vitae
... and what, pray tell, is the name of the mill? And how exactly did they quartersaw your log?
Re: It's lignum vitae
Larry in nw ohio
Yes and where is it? Larry
The company is Dreaming Creek Homes and they are off Judes Ferry Road in Powhatan county Virginia.
Their main stay seems to be timber framed homes. Their bandsaw was set up to saw very long timbers for that operation. I have no idea how they got into the vignum vitae business, but that was obviously huge for them, of at least they have a huge amount invested in it. Its a father/son operation and we were dealing with the son. He could not have been nicer to us. Did I mention they had a $12,000 (that's what he said, really) redwood flitch that is four inches thick, 55" wide and 20' long they were turning into a spectacular table?
They had similar but shorter flitches from the largest sycamore tree in Virginia. I think some of those may have been $800, but don't quote me, I was completely overwhelmed.
They sawed the log by squaring it up. As the slabs came off they ran them through a gang saw with two blades and lasers that showed the sawyer where the cuts would be. These were obviously plain sawed. They set them aside to not mix them with the quartered stuff. Then they sliced the log into sections that were about 6" thick and set them aside. Then they took each one and set it up on edge. If the piece was oriented correctly they took 4/4 boards off one after the other. If the grain orientation were opposite what they wanted, they took a 6" slice off and rotated it ninety degrees to reveal the quartered face and sliced it into six boards. Clear as mud?
The result is that we ended up with a lot of 4/4 X 6" quarter sawn stock. And some that is 5/4, 8/4 and a little that is 16/4.
We are eyeing the 4/4 X 6" stuff as possible flooring. Now I just have to build a house worthy of it.
I thought to quarter saw you quartered the log and then took a cut off one face and then the other, back and forth. This would produce the most nearly quartered lumber but they would be of many varied widths.
A funny experience. As they started sawing and the slabs started coming off, I was tempted to save every square inch. Small sort of vaguely triangular pieces where you could get a piece maybe 6" wide on one end tapering to nothing a about 3'. I was practically diving into the trash pile. Later as the yield increased, it was "throw that crap away, I don't even want to haul it home."
Thanks, Barry
Quartersawing is most properly done by cutting the log into quarters and then turning the quarter up on a 45º angle and sawing sequential boards out. You end up with varied widths from the tips to the center and back again. This way, you get some wide stock that is almost perfectly on the quarter. The cut turns to rift by the time you get to the ends. At least, this is how Sam Talarico saws white oak, and he's one of the premier suppliers.
Sounds like these guys are really into it. And, I heard that someone was trying to corner the lignum vitae market -- maybe these are the guys. Thanks for the info.
Re: Thanks, Barry
I had forgotten that method. Would not work well on a bandsaw mill since the blade is horizontal and it would be difficult to support the quart of a log on one "corner".
You should have seen them hauling these logs. They brought a big flat bed truck and a Bobcat on a separate rig. I took one look at the Bobcat figured it would run away whimpering once it got a good look at the logs. They picked up the first one and the log was about ten inches off the ground and the back wheels were about ten inches off the ground. They drove it over to the truck on two wheels. I would have been funny if it weren't so scary. It had just enough lift to hoist it up onto the truck bed. The logs were on the driveway that had a very slight incline. They had to get behind them to lift them because the Bobcat would not back up the hill. Two of them were titter tottered onto the truck. They other two were slightly more conventionally loaded.
In the midst of all this I noticed the truck had "Chesterfield Trading Company" (large local commercial and industrial supply company) on the door. I asked how it was that he got to use their truck. Turns out the Benny, the driver Owns that company. He was complaining that the Bobcat was not as big as his, his was "up the country" so he borrowed this one from James River (Large local Dealer). His grandson was the bobcat driver. This was a play day for them. I had tried and could not find anyone to move the logs for me. Clearly pays to have connections. Dreaming Creek had built his house and barn and his house on the beach in NC. I was out of my league.
So far, I have been impressed. They have hit every mark. Called when they said they would, Came when they said, got the logs moved, sawed them reasonably well,.... I am more used to the construction industry where things seem to happen at a more random pace.
Re: Thanks, Barry
Larry in nw ohio
Barry Thanks for the info, I doubt if I will be able to get out there ever, but never know. I`ll keep the info where I keep all my forgotten information. Also great story. Larry
