same story I got from a lighting engineer
Bill Tindall
I find what people do with fluorescent lighting astonishing. There is a huge difference in the appearance of stuff under lights of any kind that depends on the kind and quality of the lamp(bulb). In the case of fluorescent lamps the range of appearance is especially great.
The lamps work by exciting mercury atoms with an electric discharge. The mercury emits invisible ultra violet light. The tube is coated with various minerals, which vary with lamp type and lamp quality, which turn the invisible light into colored light. The colors emitted depend on the minerals coating the tube. By diddling with the mineral content the mixture of colors the lamp provides can be varied from red to white, and the illumination varied from something similar to incandescent to bright sun and everything in between.
People often complain that they don't like fluorescent lighting. It may be because they chose the lamp with a color output they found objectionable. Indeed, things look awful under cheap "shop light" and I don't want to face a 5000K sunlight lamp in the bath in the AM.
Fluorescent lamps should be chosen according to the lighting need. Most people will be more content with a redder 3000 to 3500 Kelvin lamp in the kitchen and bath. But it is best to experiment with different lamps to see what you like best. In the shop I mix 5000 K( resembling sun light) and 4000K (redder/softer) lamps of high quality. The quality is indicated by the CRI number. 85 or higher is a good lamp.
Unknown lamps would be relegated to the garage or barn.
BTW, T12's will no longer be manufactured after Jan1 according to the local lighting store. As a practical matter most are no longer manufactured now and stores are working off inventory.
