Let's talk about weed whackers
Joe Pack
My old electric Craftsman weed whacker has served me for over 20 years, mainly on a small lawn and light trimming, but it is like me...getting too old. So, time for a new one I think.
Okay, time to start the debate...what do I look for in a gasoline-powered string trimmer? I will use it for the typical sidewalk/driveway trimming, plus some "jungle" trimming around the tree/vine/underbrush perimeter of our lot...about 1.25 acres. What are your favorites or least favorites, and why?
Let the debate begin! :b
Re: Let's talk about weed whackers
Stuart Hough
Joe, take a look at the 18 volt Lithium-Ion cordless models from Ryobi and Craftsman. They have a longer battery life now, and with an extra battery charged up (which you might not need on a regular basis) you might be able to do your entire property with zero fuel, and no local emissions. Startup cost would be not too much higher than a gasoline-powered model, but admittedly higher than a corded electric model. when gauged against the fuel model, it should pay for the difference in fuel and unit cost fairly quickly.
Bob
Bob
The only thing I have against them is the battery replacement cost. I need two new Dewalt batteries and it will cost me about $200.00. Not a good selling point for a tool that should last 5 or more years. Just my two cents.
I have an Echo straight shaft gas model that I purchased new this year. It replaced an Echo curved shaft model that I had had for years.
It is not light - but I've got a big lot w/ a lot of slopes to trim. Having a straight shaft makes some difference in reaching up the slopes. I can plant my feet and trim a larger area before moving on. I would not get a curved shaft model for my lot (YMMV).
If I were going for a gas model, I would go for an Echo or a Stihl. I know very little about battery powered models.
Only one to choose from.......
Bill Tindall
if you will be doing tall grass. The Stihl head doesn't wind long grass stems around itself; others do.
Echo  for me
del schisler
i have echo weed wacker, headge trimer, pole trimer, All at least 15 or so yrs old
and no trouble except the little plastic primer bulb which i have change due to the gas , also change the gas lines in them , easy to do. All has the orignal spark plugs, They start on the 2nd or 3rd pull every time. Just keep them in clear order and they will be good tool's. my 2 cent's i didn't read any other post yet
steve mackay
OK . . . I replaced my "C-word" electric. It was actually on sale at ACE. I was THRILLED ! Now . . . I watch all my neighbors goof around with those gasers for twenty minutes trying to get them running. They fiddle with the gas, the mixture, the plugs, the filters, the idle, yadda, yadda, yadda. Then they trim for ten minutes and start all over. I plug-and-play and am done with the job in fiftenn minutes. I'm out feeling like king of the world surveying his spiffy domain while they are cleaning spark plugs for the second time in half an hour. It just baffles me. I KNOW I'm not a manly man by not useing a gaser. And I'm OK with it.
Yes, the mower has a tail also. ;) I haven't SEEN a spark plug in ten years.
Don Orr
I have a Stihl and it works well. Straight shaft gas model. Probably bigger than I really need but I have a big yard and wooded areas. They make a wide range of sizes and even have models with interchagable heads for different jobs. I am happy with mine-no problems in several years. It replaced an old Lawnboy that was my fathers'. It took a lot of hard use to finally kill it.
Robin Corell in Atascadero CA
I have a Honda that is still gong strong after 11 years. I was a bit skeptical of the longevity of such a small 4 stroke motor but it has been a typical Honda, reliable and cheap to maintain. The advantage of a 4 stroke is not having to mix the fuel and more torque so it doesn't bog down when cutting thick stemmed weeds.
I am a fan of stihl and own two of their chainsaws but I will buy another Honda weed whacker if mine ever dies.
Robin
Weedeater
Joe Pack
Thanks everybody. Sorry to take so long getting back...busier than I am used to.
