Urethane resin *LINK*
John in NM
There are many sources, but I buy it from the guy in the link, mostly because he sells both silicone and resin, and has everything clearly priced - most industrial suppliers require you to write for a quote, and some don't even sell small quantities.
These resins actually cure quite hot, any moisture in the mix will cause foaming as it turns to steam, causing the pour to expand about 5x, ruining the casting and making a huge mess. Most of the gas pulled out in the vacuum is air dissolved in the resin rather than entrained bubbles from mixing, hence the very low pressure needed to degas - something like 27 inches Hg of vacuum, a bit more than required to boil water (I forget what that is in PSI, a fraction of a pound in any case).
Casting urethanes are actually pretty neat stuff, thin enough to pour nicely and tough enough for many applications where injection molding would have been used 30 years ago. It is really hard to design a good mold for a gravity pour though, I've yet to have one work well on the first try, usually it takes me three or four re-designs to get one that really works well
I've thought of using them for large scale filler like I used to use West System epoxy in mesquite, but on the whole I think the epoxy really is the idea stuff for that job. I'd bet the epoxy would benefit from a thorough degassing though, I remember many iterations of filling little bubbles
Urethane resin
