Jointer dust collection
Doug Ridley
I have an old open base jointer and want to hook my DC to it. Can I just enclose the base and hook it up near the bottom or do I need to build some sort of chute from right under the blades?
Doug
Doug Ridley
Doug
Re: Jointer dust collection
Larry in nw ohio
Doug In my opinion you should get the hose as close to your knives as you can. By that I mean get somekind of D.C. fitting for the end of your hose and get that up as close as you can to the outlet of your knives. Good Luck. Larry
Clementine
With a jointer you'll have much more to collect in chips than dust, so you will want to use a drum between the jointer and dust collector.
Bill Howatt
yes, a separator is needed unless you want to be cleaning out the bottom bag of your DC frequently which on a lot of them is a pain compared to dumping a drum.
Also, if you are building a chute or other structure under the jointer try and keep the path as direct and smooth as possible. The chips have a nasty habit of easily getting trapped and when that happens they build up and block the path.
Bill
Larry in nw ohio
Doug If you could post a good picture of the area where you are talking about maybe we could help you more about what you could put in it and what kind of DC system you have. Larry
Doug Ridley
Thanks to all who answered but I have changed my mind. Rather than go to all the trouble to hook up my DC to the jointer I've decided to build up the sides and scoop/suck it out when it starts to get too full. I mostly carve and use the jointer a lot less than most so I think this will work okay. I appreciate your suggestions.
Hal
As suggested by Larry and Bill, either get your intake as close to the blades as possible or install a chute. The configuaration of your machine may dictate which is preferable. I think a chute is employed on most machines now. I find that Poplar seems particularly prone to clogging the chute when face jointing. Regarding a separator, the amount of chips produced by the jointer is relatively modest IMHO. It's the planer that really fills up the DC. Good luck. Hal
Hal
You posted your message while I was typing my reply. Anyway, a possible note of caution. Without the pull of the DC, you may get a lot of chips coming out of the blade slot. Or your idea may work just fine.
Doug Ridley
Thanks, Hal. I have everything else hooked up to a 2HP DC and since I don't use the jointer that much anymore I really think scoop/suck out will do me fine.I just want to build up the sides enough to make a fairly large collection bin.
I would just get a hood and 4" hose. You can get an inexpensive plastic hood for not too much. I have my jointer hooked into my DC system.
Highland Woodworking sells an 8" jointer hood. They also sell a 6 1/4" x 6 1/4" "universal hood". You can also find others. If you want to make or adapt one out of HVAC parts, you can do that.
