Now we are making power.....
Jesper, Denmark
Jesper, Denmark
5.4 kW capacity, annual expected production in this geographical and climatic location ( 55° North) about 5.0 MWh per year. Installed price, $20,000, annual power savings $1,600. Plus some tax advantages.
No fuss, no muss, just make the investment and the electronics keep tabs on it.
Installation on a "difficult" clay tiled roof at 45° angle took 5 man-days and was done in two actual calendar days.
This will just about handle my electricity consumption, so no more CO2 or taxes related to CO2. It makes you feel good to do good and it's also a decent investment.
Now, if I could figure out how to do something similar with the heating???????
Re: Now we are making power.....
Larry in nw ohio
Nice job Jesper, I`d sure like to do it, but we are to closed in by trees, same for a wind machine. For heating couldn`t you do geo. Some people I talk to around here like it. Larry
Mark Nowicki
With an NPV of about minus $5,700 (10 year, 2.0% disc. rate) it is not a "decent investment"
Mark
Howard Norman
I consider solar panels a "feels good" investment. If that is what you are looking for it makes sense. If you want a real cost effective investment I don't think that solar panels qualify for that.
From someone who spent many years trying to make financial sense out of solar cells.
Howard
Richard McComas
What's the expected life span of the panels? Any maintenance issues?
Bill Howatt
5Mwh=5000Kwh so at my approximate cost of $0.10 per Kwh I would be saving $500 per year which is about a third of your saving.
My payback period forgetting about Mark's NPV or FV or other accounting stuff which does matter but complicates things, is $20,000/500 = 40 years.
Your payback period using my simple estimation is about 13 years which is not off the wall. However, there is the NPV factor, maintenance but the other thing in your favor along with the tax saving is the cost of electricity is unlikely to be going down in the future.
Interesting to see how it works out for you.
Bill
Stuart Johnson
I like the idea of doing all we can to eliminate our energy issues. I'm confused on the production from your solar panels. If they are 5.5 kwh does this mean in a ten hours they would produce 55 kw? If so then in a 30 day month it would be 1,650 KWH. At .10 a KWH that's $165 a month or $1980 a year. Any days with more than 10 hours is a plus and any with less is a minus. I don't understand the 5Mkwh it looks like it would be closer to 20Mkwh.
What is your current heat source?
Jesper, Denmark
Jesper, Denmark
Predicted panel life is 50 Years. Predicted inverter life is 20 years.
Jesper, Denmark
Jesper, Denmark
Invsment of $20,000 and return of $1600 savings.
You figger it out.
Jesper, Denmark
Jesper, Denmark
Maximum power output is 5.3 kW. Anticipated annual power output id 5 mW/h.
My current cost if purchased is $0.33/kWh.
Mark
Nice job . I assume you have a battery bank that is being charged and then used to supply DC then with inverter to AC. How many batteries?
RobCarr
Re: Now we are making power..... *LINK*
John McGaw
I suspect that, since Jesper is on the grid already, that there are no batteries involved and that it is a grid-interactive system. Given that Denmark is civilized and has reliable services (unlike Tennessee, where I live) that actual loss of grid power would be a once-per-decade event.
http://en.wikipedia.org/wiki/Grid-tie_inverter
WOW! $.33/kWH
The local rate here in Indiana varies according to usage. Top is less than $.08 and reduces as usage increases. I calculated mine a year or so ago - with all the hidden charges (connection fees, taxes for everything etc.) it was under $.08. With rates more than 4 times mine and the government subsidies it may pay there. One issue you did not figure in is the annual loss of efficiency. Manufacture's warranty in the USA is normally guaranteed to be at least 90% at 10 years and 80% at 20 years. Granted that is conservative, but they certainly won't put out 100% over the years. By the way none of the manufacture's warranty anything past 25 years.
We pay about $0.13 here...
John in NM
Plus the $16 service charge..... I'd love to get some of that $0.08 rate, but I suspect you folks make up for it and then some when it comes to property taxes :D
vamatt
Nice. I appreciate people who make a difference.
Jesper, Denmark
Jesper, Denmark
There is no batteries involved. The inverter needs exitation from the 50 Hertz grid to function, and cannot - like vind turbines - produce if this exitation is not there, such as in a failure in the grid.
Any excess power is fed into the grid for use elsewhere. The metering is on a net consumption basis, so that the kWh fed into the grid during the day can be recovered at night, meaning that the meter runs both ways. The accounting is done on an annual basis, so if I produce more than I consume, the power company pays me $0.10/kWh. If I use more than I produce, I pay them at the normal rate, which is around $0.30/kWh.
Since all the 400 volt distribution grid is now underground, and they are in the process of also putting the 10 kV distribution underground, power failures are very rare. It basically only happens when some idiot with a backhoe digs up a cable - and that is usually fixed very quickly.
The decision to put the power undreground was made after a major hurricane in 1999. We only get one of these every 100 years or so.
Jesper, Denmark
Re: WOW! $.33/kWH
Jesper, Denmark
There are lots of considerations I did not mention. The post was intended as general information - I did not want to write a whole thesis on photovoltiac power 8)
In the USA, you are blessed with very low costs of power - both electric, gas and automotive fuel. That is not so here in the EU, where taxes - both VAT and CO2 taxes makes fuel at least twice as expensive as in the USA. Current Diesel and gasoline are about $2/liter - or $7.57 per US gallon. Consequently, people tend to drive microcars and superinsulate their houses.
Also, income taxes for both earned income and investments are typically taxed at about 50%. This may sound like a lot - but is not realy that different, when you consider that it includes social security and health care.
Please, this is just information for general illustration - not in any way a comment for or against any political issue.
Stuart Johnson
I'm still not understanding. Does the system put out a maximum of 5.3 KW in an hour? If so and you get 8 hours a day of sunshine and assume you get the maximum output that would be be approx. 42 KWH or roughly 15,000 KWH in a year or 3 times the 5mKW.
Kneale Brownson
My neighbor just installed similar at no cost
Kneale Brownson
through a company that "sells" the power the panels produce to the power company. The installer looks at his average electric bill for the last several years, sets a power fee he pays monthly and after 20 years he owns the panels and connection to the grid. At that point, the power company is supposed to pay him if the panels produce more power than he uses.
Jesper, Denmark
Jesper, Denmark
The panels produce a max of 5.4 kW in ideal conditions. So, say the midle of the day with hazy sunshine they deliver 5.4 kWh in one hour. However, since they are fixed on the roof, the ideal conditions only exist in the middle of the day, so early in the morning and late afternoon, the output is significantly less.
This morning, when it was cloudy and just barely light, the output was 56 Watt. Just a little while ago, in the middle of the afternoon with hazy sunshine through a thin cloud layer, they produced 3 kW.
The predicted annual production of 5 MWh is based on the local expectancy of the amount of sunshine over a whole year. In the dead of winter, when we only have 6 hours of daylight, the production is quite low. On the other hand, in summer we have 18 hours of daylight and production is high. The accounting is annualized, so once per year, the consumption and production is calculated and the account settled. This has to be based on a calendar year, as there is a tax implication.
Jesper, Denmark
Re: Addendum.....
Jesper, Denmark
The power company replaced all the meters a couple of years ago with meters, which report consumption electronically via the power lines. You can watch your consumption down to an hourly basis on their web site with a couple of days delay.
The purpose was to save the cost of meter reading and eliminate the uncertainty of consumer read meters. The benefit to the consumer is that you can figure out where you use the most power and do something about it. In my case, it is being in the shop, which has 1.2 kW of lighting installed. I did consider LED "fluorescent" tubes, but they are as yet too expensive and too unreliable. Maybe in a couple of years......
Jason Roehl in Lafayette, IN
Heating...
Install one or more solar "hot boxes". I have one on my roof and really like it--I am thinking of building another to add to the system.
Basically, it's just a box with a 4'x8' glass panel, dark interior, a snap-disk thermostat to turn on the fan when it's above a certain temperature, a blower fan (~400 CFM, 1/5 HP) and the insulated duct work in my attic.
It's angled to take advantage of the sun in the coldest part of winter, and during that time, on a sunny day, it will run from about 10 AM to 4 PM, with about 30 min of cycling before and after that. During the full run time, it can keep the furnace from running even when the outside temperature is 10ºF.
Jason
Re: WOW! $.33/kWH
Howard Norman
Jesper, you have a situation there which is quite different from us here in the US. My earlier comment of solar power being a "feels good" thing may not apply in your situation but it does for most US situations. In the US the exceptions are mainly when you are building off of the grid and the utility wants tens of thousands to bring the grid to you. I know of one such parcel of land within a five miles of me where the utility wanted 70K USD to bring the power in.
I can believe that in a case like yours the cells would last for many years before they are damaged enough to require replacement.
Dale Lenz
Re: Addendum.....
Dale Lenz
When our power co. changed our meters out to do the same thing as yours, they jump the monthly meter charge from $6 to $22. Obviously, I don't like it! The power co. boast that they have not up the price for KW, :( !
