We value your privacy.
I just finished my router table and now need a panel to mount a ON/OFF button with a receptacle in the back to plug in a router and can't seem to find one as an assembly. Of course I know I can make one but I would rather get on I can just install does anyone have a resource?
I got one of those narrow power strips that already had a switch in it. Then I disassembled it and rewired it so 4 outlets are unswitched and 2 are switched (for router). I marked it to indicate which end is for the router. The extra outlets mean that I have receptacles whereever my router table is rolled. Works pretty good. About 14 years and still going.
Bob I used a switch, like that is used in a house, and ran that to a plug where the router plugs into, and that also turns on the DC system also. I don`t really think that is what your looking for, but either way you go it`ll take just as long to do. Good Luck with your setup. I hope you post pics. Larry
I found it to be relatively easy to do what I did with my router table (cabinet), and it probably didn't cost more than the commercially offered all-in-one switches. I put a double receptacle box on the back of the router table, with one unswitched GFCI receptacle, and one switched receptacle. I usually use the unswitched receptacle for the work light, and the switched receptacle is reserved for the shopvac. However, I have connected the table and the fence to my central dust collection system, so I don't currently use the switched receptacle. On the inside back of the table, I installed another switched receptacle (that I plug the router into, of course). On the front of the table, I installed another box with a SPST switch (like you would use in the house for turning on lights).
Danger, Will Robinson!
I don't like my simple light switch installation. It's too easy to brush up against it while working in front of the table, accidentally starting the router. If I were to recess it so that couldn't happen, it might be too difficult to turn it off in a hurry. However, it doesn't really matter how much of a hurry you are in, the router can cry havoc a lot hurrier, so any simple guard on the switch would probably be a good solution to the problem if you can't find a paddle switch you like. Another potential for wreaking havoc is that I installed it horizontally, so to take up less room on the front of the cabinet that might be better used for drawer fronts and more router bits. Being left handed and slightly dyslexic, I can get confused about which direction is off.
Another potential problem with using a switched receptacle to power the shopvac is, if you have a high horsepower vac and a high horsepower router that is not slow start, you might draw enough peak current to trip the circuit breaker. This is a potential problem whether you make or buy your controls, so do the math.
Good information to know. I wanted to use a motor control set up but after seeing the prices ($100.00+) I think I will go a different rout. Back to the drawing board.
I have an older design Rockler switch mounted on my table (mushroom off) that I can reach with my knee - seems like all the available switches have paddles now. This is the "modern" version of the switch I used.
As a "temporary" measure (until I hook it to the central vac system - going on 5 years now) I used one of the switchable outlet strips to plug both the router table and vacuum cleaner into - works well for me, as I can "Bump the button off" with my knee without letting loose of my parts. I have one of the largest routers mounted in my table (PC 7539) - switch holding up well. I did notice the current switch shown at WoodCraft has 2 outlets for vacuum and router built in.
