THE WOODRAT IS BACK!
Conversion Varnish
Conversion Varnish
Conversion Varnish
Bob Boswood
Does oil solvent based conversion varnish over 3 yr old water based regular poly make sense? Will it add an amber tone to existing finish? I live in North Pole AK and no one stocks water based C/V locally. Water based is not required in our state so it is not stoocked in stores. I have to sand and refinish about 20% of the doors doors and drawer fronts in a 3 yr old kitchen I built. I want to beef up the finish on all of the cabinets as well. I am quite comfortable with spraying any finish as long as I do a few test pieces first. I've gotten away with only having to totally redo 20%, don't want to screw the rest of the cabinets not effected thus far.
Bob in Ak
Re: Conversion Varnish
Bill Tindall
The best answer I can provide is that I can't predict the result. Sherwin Williams Kemvar does yellow. They make an "alaphatic" version that yellows less.
Whether top coating with something more robust will add durability depends on what your durability issue is. If it is abrasion then an overcoat of something more abrasion resistant should improve the situation. If the issue is moisture then it is less clear.
Both Target Finishes and General Finishes have good technical service departments that can offer better advice than I on this particular situation. Target ships finishes from their factory.
Larry in nw ohio
Bill the way you sound on some of your posts, if I happen to stop by when we are on vacation I may pack you in the trunk and take you home with me to help finish my bar stools. ;) Larry
Re: Conversion Varnish *LINK*
Bob,
The old rule of "Acrylic/Latex over Oil is OK, but Oil won't stick to Latex" may (but may not) apply here. You could have a mess to deal with.
I'd strongly suggest you stay with the waterbornes, easy to get by UPS. Suggest you contact Jeff Jewitt at Homestead Finishing [link] and take his recommendation. The General finishes he carries are KCMA tested and approved. You can kick them up even higher using the crosslinker additive.
m
Homestead
Dick Coers
Compatibility and film thickness are your concerns here, not yellowing. You may just soften the entire old film with the application of a solvent base material on top. Also, most finishing companies are very concerned about the final film thickness. Too thick and you get cracking. Personally, I would run away from that job. Who knows what the cleaning crew has used on top of the present finish to clean, or "polish" it as well.
Bob Boswood
Thank you one and all. Unfortunately I cant run away from this job as it is for my ex wife in the kitchen I built for her in our house that no longer is our house. Matter of pride of workmanship at this point. I just want to be sure I never have to enter that house again in my lifetime. It was my mistake and a costly one in the amount of time its going to take. I will contact homestead and ask for their advice. Again thank you again. I have learned good lesson.
Bob in AK.
