Gluing up a chest of drawers
Bill Tindall
This case has 26 parts to be assembled without getting one in backwards or out of place. Here is what I do to make it all go smoothly and not make mistakes.
Step 1 was dry fitting every part to see that they would slide together easily and nothing was missing (it was- I forgot a kicker for the top drawer middle). Also make sure the assembly is square by measuring diagonals. If the joinery is right the case will self square. People make the mistake of making joints too tight and then having problems during assembly. If it doesn't slide together with no more than light tapping the joint may be difficult to assemble once the glue swells it.
Step 2 is to lay out everything that is needed and in the order that it goes together. The dividers are all in order with chalk to indicate order and position. Runners are in a stack to the right as they go into the case. Note I have chalk marks all over the place to indicate orientation and position.
I use liquid hide glue as it has the longest working time and it lubricates a joint during assembly where as yellow glue is more apt to grab prematurely.
The back dividers are installed first so that the glue sets a bit and they won't scoot out of position when the front dividers and runners are installed.
Assembled case waiting for the glue to set.
I will just be changing the rail size.
