We value your privacy.
I bought a 2.5 amp electric tiller, it`s about the size of a weed trimer. I am in need of slowing down the tines. Could I put a reostate on it without hurting the motor, and if so how much would something like this cost and where would I get one. I seem to remember seeing something in WW catalogs that they have one that can be put on a router, would that work. Thank you Larry in nw ohio
If the tiller has a universal motor (AC/DC motor with brushes) then one of the speed-control boxes sold for routers should work. Be forewarned: as you slow the motor you will be reducing the available power so the tines will be able to do less work and may jam on even fine roots --- those electric tillers probably can't handle much load even at full speed.
Thanks John, I`m not going to over load it at all. Not going to till up a garden or any kind of soil. I`m trying to just till the mulch in the landscaping to just air it up some, kind of make it look like new somewhat. I thought that a speed control like used on a router would work, AC/DC, because I have been useing a speed control on a fireplace fan for close to 40 years and have not giving me any trouble at all and that is a simple light dimmer, and it has no brushes. Any comments? Larry
Since you have a AC/DC motor any motor (or dimmer) control with enough minimum amp rating will work to slow the unit down. All of the inexpensive units work by "chopping" the sine wave off at the top creating "Pulsating" AC. The top or highest voltage is always there but it shuts off, depending on the setting, the length of time the voltage is passed to the motor. However be cautious as many of these motors depend on air movement from an internal fan for cooling. When the motor is slowed the fan does not move much air and if the unit is loaded hard it may overheat. Variable speed motors are usually designed to allow for this and have over-sized fans to compensate.
Thanks Larry, I knew that , but of course I forgot about it. Thanks for reminding me. Like I said in a different post, this is not going to be used very hard. I wander if I could maybe put a little computer fan inside to help keep it cool, there seems to be room for a small one. I love to tinker. Larry
