How to set the fence on a saw sled
Bill Tindall
There have been posted a number of fiddly ways to establish the fence on a saw sled perpendicular to the track of the sled across the table saw, thus ensuring that cross cuts will be square. Here is another way which is quick, precise and only involves using a trammel (home made or not) for a compass.
This technique is illustrate by using a compass on a piece of paper. It relies on the elementary principal of constructing a line(in this case the fence) perpendicular to an established line (in this case a saw kerf). The red outline represents the surface of the saw sled with the saw kerf represented by the black line.
Step 1 Swing an arc using the saw kerf as the center point as shown in picture 1.
Step 2 Centering the compass or trammel on the saw kerf at the point where the fence is to be located swing an arc that intersects the first arc.
Step 3 Align the fence with the intersection of each arc. Fence is represented by the green line.
Re: How to set the fence on a saw sled
Simple geometry (construct a perpendicular) does work. I, however, prefer to use the mechanical method.
1. Make the sled without the fence.
2. Make the initial cut 80% across the sled.
3. With power off and the blade high, slide the sled to the end of the kerf.
4. Lay the short leg of an accurate framing square against the blade's plate (not the teeth).
5. Set the fence using the long leg of the framing square.
I set my bandsaw sled the same way except I use one edge of the kerf as the reference line.
Hal
I use Pythagorus and the 3,4,5 triangle. 15,20 & 25 usually is OK.
I Use Him
to lay out walls :D
[also to check the accuracy of my framing square ;) ]
Alan in Little Washington (NC)
The problem with the tramel method is how do you reliably place its tip in the kerf made by the blade which may be 1/8" or 3/32" wide?
Don't sweat the initial placement, it is a waste of time. I just use a square to get it close, use a screw to anchor one end and clamp the other. Then I use the five cut method to get it spot on before I glue the other end. Once the glue sets I add a screw to that end as well. On my adjustable fence sled, one end pivots and the other has a zero stop. I locate the zero stop using the 5 cut method also.
that is easy
Bill Tindall
I thought it obvious that any line parallel to the kerf can be used. In practice I place the trammel point as close the the kerf as I can for each setting. One could make a scribe mark off-set from the kerf. It directly follows that the precision will be determined by the width of the arc lines. On my sled the arcs were swung the length and width of the sled so at most the out of squareness of a cross cut the effective length of the sled is a line width. Good enough.
Put a drop of glue on each end of the fence, align the fence with the arc intersection and let the glue tack. When glue is set enough to immobilize the fence screw it down from the back of the sled.
Another vote for the "5 cut method"....
roger lance
but it did take me 7 run throughs to get "square" using a woodworker's caliper at about .005" over a 12" test piece.....good enough.....on a test piece for cutting tenon shoulders, all four cuts merged....I'll take it.
Brian from Monument
I used something like that 5 cut.
But in the end the only thing that matters is the proof of the squareness.
That can only come from cuts.
So why not start with that method.
The OP laid out a sound way in geometry and drafting of constructing a perpendicular line.
Another post laid out a slightly flawed way using the saw blade.
I don't use the saw blade. As any heel (hope I have the right term) in the blade
will result in the fence being out of square. If the blade is not absolutely parallel to the mitre slots. That method wont work. Rely on the kerf. After all the where the blade is is only part how the cut goes.
The sled is using the mitre slots.
So the kerf is king! Long live the kerf. (and the 5 cut method is part of it)
suggestion to "5 step" enthusiasts
Bill Tindall
Many readers are not going to know what you are talking about. Will someone offer a link that describes this alternative means of locating the fence? Or better yet, write it up in Article Format and post it and I will include it with what I wrote as a comprehensive Article for the WC Articles section.
another link on youtube.....
roger lance
if my link below does not work just go to youtube and enter "5 cut method".....
http://www.youtube.com/watch?v=UC_iF5pZxml
Bob
Re: 5 cut method. Link
Bob
http://youtu.be/UbG-n--LFgQ
I found this to be the fastest and the most dead on method, mine is less then .0005 out
