Electrical (OT)
Larry in nw ohio
The electrical question in a past post brought up a question when conduit came into the mix. Can any of the PVC piping be used as a conduit? I know they use some on buried runs some places. Thank you Larry
Electrical (OT)
Larry in nw ohio
Re: Electrical (OT)
Jason Roehl in Lafayette, IN
I don't know whether you can use, say, Schedule 40 PVC pipe for conduit or not, but I don't know why you'd want to do so. Non-metallic conduit is PVC, and it's much cheaper (gray, from what I've seen).
Jason
Re: Electrical (OT)
Bob
Grey yes I just did an underground run 100 ft. with it and #2 Aluminum it is cheaper. I believe code don't allow schedule 40 anyway.
Re: Electrical (OT)
Kneale Brownson
I've seen electric buried in schedule 40. I think you want to use the gray stuff when it's exposed.
Re: Electrical (OT)
Carol
Don't you want to use the grey because it tells people electric wire is inside, as opposed to white schedule 40 which might mean water inside instead? Just askin'...... Thought that was the point for the color differences. I'd be surprised if there was a composition difference.
Re: Electrical (OT)
Bob Lasley
Larry,
Codes vary from place to place, but here in Oklahoma PVC conduit is allowed in many installations now. PVC conduit is manufactured in both schedule 40 and 80. We used to use primarily schedule 80 conduit, but I understand the schedule 40 is now allowed as well. All of the PVC conduit I have used is gray in color. Check your local codes to be sure.
Bob
Re: Electrical (OT)
Jim DeLaney, Austintown, Ohio
All the conduit in my 23 year old home/garage/shop/barn is gray PVC. Sizes range from ¾" up thru 3", with underground runs up to 100 feet.
It's been code-approved here in NE Ohio for at least 25 years.
Re: Electrical (OT)
John Veerkamp
In addition to the color coding, my understanding is that water pipe (white schd 40) must meet pressure ratings and be manufactured to potable water standards. Grey PVC may also have some UV inhibitors for use above ground.
Re: Electrical (OT)
John McGaw
My understanding was that grey PVC conduit definitely included UV inhibitors. I also suspect that it may have chemicals included to inhibit flame spread allowing its use in risers.
