Sump pump(Little OT)
Larry in nw ohio
I considered this a little OT because this is a critical part of my basement shop. If it quits my shop is down the river, sort to say. Also I`ll help Barry so he does`t need to post about it and I don`t think he has yet :D What do you think the best sump pump is. I have had Liberty and they seem to do very good,and how about a Zoeller? I`ve had Ft. Wayne`s they also seem to do well, also I`d like made in the US if possible. Thank You Larry
Re: Sump pump(Little OT)
Nat Robison
My neighbor is a plumber and helped me plumb a new bathroom in the basement. It needed a sewage ejector pump and we put in a Zoeller. No complaints after 5 years.
Ditto, My Plumber swears by Zoeller.
I actually don't have a recommendation for a brand, But let me stress you need a back up power supply and perhaps a backup pump. Power failures often occur when sump pumps are needed the most.
Larry in nw ohio
Barry Yes Ever since I had a home I have had two pumps in the hole. Now my SIL has a home and believe it or not, he has taken my advise and put two in his sump hole also he put a back up water ran pump. But now we need to rework it, because he has trouble with water in his ares. There must be some sort of sand vain around his house and water runs into his sump hole all the time. So we need to stay on top of his pumps so they do not quit on him. I think we1ll get him a Zoeller main pump and a liberty for a backup, I have an extra, and the water backup for emergency. Any suggestons? Thank You Larry
Pete in Holland MI
If you are on city water, they make a water activated piston pump system that will work in the event of a power outage.
Yes, they use water to pump water, and water costs, but is is a pretty cool back-up pump that won't need you to be there to start it, unlike a generator.
Pete
Jesper, Denmark
Jesper, Denmark
Grundfos is considered the cream of the crop in sump pumps and water circulation pumps. It may not be built in the USA, but Made in Denmark ain't too bad :)
It is actually an active consideration, as I have had a little problem with high groundwater level and occasional seepage in the basemment floor. I am presently having a well dug in the basement and a Grundfos pump installed to lower the water level under the house. The hope is that a perimeter drain is not necessary as the permeability of the subsoil seems prety good.
