We value your privacy.
I am looking for the best method to cut thousands of (4 to 6 inch diameter) 1/4" plywood discs. Half of these discs will need a 1 1/2" hole cut in the center as well. Any machine that you know of capable of the mass cutting of these discs? Thank-you for any advice, Steve
1/4" plywood is actually not that difficult to cut. How about a "stamping die"? You could get one in a donut shape. You would need a press, probably something that could exert a couple of hundred pounds (or more) of pressure.
I've used stamping dies to cut plastic sheets (1/4-1" thick). I've used knives to cut 1/4" plywood. I don't really see any reason why a die couldn't cut plywood.
If there ever was a job for a CNC machine, this is it. Check around for a CNC job shop. You might be real surprised at the savings over doing it any other way.
1/4" plywood would be outside the comfort zone for the budget-priced laser machines anybody is likely to have in a small shop and they would be pretty slow doing it. Medium-power laser (100-200W?) would do a slick job but the machines are pretty rare outside of industry. Water-jet abrasive cutting would do the job very nicely but finding somebody to contract out such work seems a daunting task. That pretty much leaves CNC as my best choice and there seem to be a number of job shops around that offer such services.
Laser or water jet are capable of multiple sheet cutting, cnc probably single sheet due to holding problems. Kinda depends on cutting speed required, type of plywood, and tolerances needed. If you want to do them, a couple router fixtures could be used to cut several at a time.
If so, go to International Woodworking Fair Aug 22-26 and there will be some company there equipped to make this sort of product. Even for a thousand it is likely that a company with machinery to productively make this kind of part can make it cheaper than for you to buy something to make it.
Perfect job for a punch press operation using a steel rule die. The steel rule dies are low cost and used to blank out hardboard, thin metal and plywood parts very accurately. There is a manufacturing plant here in my city that specializes in these parts (used to make TV backs - now makes parts for things like baby beds, thin panel backs for furniture etc.). This type operation can produce several thousand parts a day at low cost with minimal investment in tooling.
Steve, I just read Larry Clinton's responce and to me that sounds like a good solution for you.
I would suggest you contact Larry and have him ask for a quote from the company he was speaking of and forward it to you. If the price is agreeable then make an order thru Larry and have it sent to you either direct from the company or from Larry. Helping others here on WC is what we are all about....right?
Want to jig up to do them yourself, here is how I would go about it.
First, I would cut my sheets into squares about 1/4" oversize. Then on a drill press, I would drill the hole through at least 2" stacks.
Then I would make a jig / fixture which had a shaft slightly smaller than your center hole, with a circle end-plate the size of your finish product, and another 3/4" mdf template which would go on top of the stack of parts. There would need to be some sort of wedge tenon, or maybe even threads, to tighten the parts all together.
Then with the top / smooth side down, go to the band saw, and saw about 1/8" outside the top disk.
From there, I would flip it over, clamp the extra length of the center rod in a vice, then route off the extra with a hand-held router, maybe with a bearing over and under. I would much rather be holding onto the router making this kind of cut, rather than trying to use a router table where my hands are on the same plane as a cutter 2" tall, on a small circle.
However, I agree with the others who suggest using CNC equipment would be a lot easier if the price works into your budget.
They used to farm out the steel rule dies to Phillips saw and tool company but I don't think they are doing the die work any more, so Kay probably has a new vendor or is doing it in house. If you are not familiar with steel rule dies they are pretty unique. A thin slot is cut in a (high grade plywood and the steel rule (a hardened flexible steel strip with a very sharp edge) is fixed in the plywood and this is the upper portion fastened into the die set. The lower is a hard material - additional punches and buttons may also be inset into the upper and lower. Due to the materials used and methods of making these dies they cost a 1/10 or less than hardened dies. The die life is quite good for limited runs < a million parts or so. The steel rule can be replaced if needed.
