Re: duck tape zero clearance insert
TomD
I would not do that since I think that tape is not strong enough, and could fold down into the slot and trap a piece. I would only want really strong, and non-sticky stuff in that area. I would weld, or possible use epoxy (on wood or composite inserts) to make a solid expantion to the slot. They sell junky zinc solder kits for aluminum, but they would be more than strong enough for this.
I don't know what the problem is with table top saws, but I would imagine there is always a solution to what is just mechanics. I don't think zero clearance is a big issue anyway, and often you can do something to solve the problem with either a jig or a process. So for instance you could take two passes so that there isn't a sliver sized piece. Or you can make a pass at a bandsaw so that only the line remains to be taken with the saw. Sleds will be zero tolerance, etc... If the worry is tear-out, a gage mark on the underside will iliminate that.
