Pic of new chair
Pic of new chair
Pic of new chair
Robin Corell in Atascadero CA
Here are a few pictures of a chair I just finished. The base is welded steel and the walnut is some stuff I milled a couple of years ago when I had access to an orchard that was removed. I have been working with wood that I mill myself for over 15 years but this is only the second piece that I have ever made that included the natural edge.
This is one of the new pieces I have been working on for the upcoming American Craft Council show in San Francisco.
Re: Pic of new chair
3/4 view
It’s kind of hard to get a feel for the design from a single picture. From this view you can get a better feel for how the two planes of the base intersect, But unfortunately you also start to lose the subtle curve of the back. The stone is from one of my favorite local beaches.
detail of the seat
The seat was milled from a root ball and as you can see the color and grain are pretty spectacular. The butterfly is made from olive and it extends the full depth of the crack.
close up of graft line
I forgot to mention that the wood is claro walnut and in case anyone is curious about the unusual figure in the back, the dark line is the graft line between the claro walnut below and the English walnut above.
Simply gorgeous
The wood and the workmanship are stunning, Robin. I imagine this is not a chair that one moves around a lot, probably more of an anchor point (and focal point) in a room.
What's the finish?
Wonderful design. The wood really speaks for itself.
Well it's about time!
Brother, I haven't seen new stuff from you in a coon's age. But when you get busy you sure know how to make a splash! That chair is a grand slam home run. Got any other surprises I should know about?
T.
Keith Newton
" The base is welded steel and the walnut"
Soooooo, If that stone is attached, I don't guess you have to worry about tip-over, or thieves in the night running off with it in the night. He he.
I like it, congrats on a nice job.
Re: close up of graft line
Mark Valsi
quite dynamic !!
Re: Simply gorgeous
Thanks Ellis. I probably should have explained that the welded steel base is hollow. I wanted it to look like two pieces of 1 ¾” thick plate welded together but for practical reasons chose to make it out or 1/8” plate. By grinding and sanding the welds flush around all the edges and not grinding the fillet welds where the planes intersect it creates the illusion that it is two thick pieces of steel plate welded together.
This method of construction also gave me the solution for joining the back to the base. The back is tapered from 7/8” to 1 ¾” where ti meets the base. I then routed out 1/8” from each side so it could slide completely into the a base, almost like mortise and tenon. This gave me the clean crisp transition I wanted.
The finish is my hybred of a single coat of Jasco brand tung oil and while it is still wet followed by General hp Poly. I am using up my last stash of Jasco on this and another chair so I am doing some tests to come up with an alternative oil finish to use in the same way. It sounds really odd but the oil pops the grain and makes it so the water based finish doesn’t raise the grain. Since the water based finish dries quickly I can recoat several times and then handle it way sooner than even a single coat of an oil based finish. I have some high traffic pieces with several years of wear and tear on them that were finished this way and they still look great. The finish is a bit soft for a few weeks and takes a full 30 days before I get good abrasion resistance but that has been true for the 100% General hp Poly finished pieces I have made as well.
Robin
Re: Well it's about time!
Thanks Tom. I've got another chair I hope to be finishing up in a couple of days and a coffee table that I'm going to be hard pressed to have ready for ACC. No worries though because I have a group show coming up in November and I will need some new work for that and I have enough work for ACC. There is nothing that spurs the creatve juices like a deadline.
Robin
Currently the stone is not physically attached but there is a piece of steel under it with a 1” tall x1 ¼” diameter piece of pipe which creates a socket for an adjustable foot and the stone has a corresponding hole carved in it to locate it on the plate. I am dragging my feet about permanently attaching the stone because I am worried that it will invite someone to lift the chair by lifting from under the stone and as strong as silicone is I don’t know if it is that strong. I have some “space shuttle “epoxy that is stronger than most substrates that I am sure would be stronger then the stone but I hesitate to use something that permanent. Any thoughts?
Robin
Not too many options
It's either permanent or risky. Either way, I guess I'd enclose a little card that tells the owner not to try to lift the piece by the stone. But you know what they say about idiot-proofing things.
Cheers,
Re: Screw on?
One option may be to weld a threaded bolt or threaded rod to the base, and insert a threaded "anchor" into the depression in the rock. Probably have to epoxy the anchor in the rock but that should solve the problem of strength and ability to remove the stone. Another option is to drill and thread a hole in the base, insert a bolt into the rock and epoxy it in place allowing enough length outside the stone to be threaded into the base. I would probably opt for the second choice and use a 3/8 or 1/2" bolt.
I'm not sure I follow what you did.
Keith Newton
But I like the mix of elements, and have been thinking along these lines for too long now. I have gathered up a pretty good collection of petrified wood from around here that I'm thinking about using for a sculpture piece.
Also, from down at the cabin, I am getting a pretty good collection of driftwood and bones that are starting to take shape in my head-bone, so it is great to see this piece for inspiration.
The problem I have with silicone, is that if you use it, and if it comes off, whether on purpose, or accidental, nothing will stick to it after that.
Was the whole + part under the seat solid steel? It is hard to tell from the pic.
Re: I'm not sure I follow what you did.
The base is welded up from 1/8" thick plate but I wanted it to have the feeling of being made from two pieces of heavy plate so I ground back all the welds and finished the corners so they are crisp and clean.
For me I don't really think about using different materials as much as different colors and textures. Its kind of hard to explain but I don’t set out to use different materials, it is more like an image will come to me with different colors and textures and I know how to interpret those colors and textures into different materials. Sometimes I end up forcing it too much but when it really works and is successful I am always surprised by the results.
If you would like some more inspiration look up Peter Pierobon some of his new pieces incorporate wood and stone and they are truly inspiring.
Robin
