Drill Press Upgrade,
George Colonel's Workshop-Havertown PA
Good Afternoon Friends,
I have all sorts of shop made tables and drill press jigs, but realized last week that I needed a cross slide vise. After looking at the many available, I chose the Palmgren 3 inch, and bought from Amazon.
While it is a better made and more accurate tool as compared to the HF 5" cross slider I use on permanent mount at the front of my mortiser, it certainly was not adjusted correctly "out of the box". I fiddled with it for about a day, put it back together. Still imperfect, but aadjustments are good enough to complete boring holes in some hand screw jaws needed to complete three kits. Now I can look foirward to Pinewood Derby time, and other projects requiring a higher degree of accuracy. I shoulda dunnit years ago.
George
Re: Drill Press Upgrade,
No more sliding by, eh?
Sounds good, Col. You'll no longer have a reason to be cross.
Joe Bradshaw
Re: No more sliding by, eh?
Joe Bradshaw
I guess that you put the squeeze on it Col.
John Veerkamp
Don't press it folks.
Ain't
that the hole truth!
Ellis knows that what goes around...
Indeed--he knows the Drill.
Good point - a sharp comment!
I hope we're not boring the Col. with all these replies to his innocent post.
I would bet he enjoys the twists
some funny replies but here's what I use *LINK*
I went through 2 of the cheaper cross slides sold in wood working magazines. Even modified they still don't work for all things. I wanted to be able to do some light milling kind of mortising as well as using it to just perfectly align holes. By adding a decent low profile vise or simply clamping the wood to the table I have been able to do all sorts of fun projects. It's heavy however so better do some curls and back work to loosen up before you throw this thing around
http://www.use-enco.com/CGI/INSRIT?PMAKA=201-2826&PMPXNO=951820&PARTPG=INLMK3
Jim DeLaney, Austintown, Ohio
Re: some funny replies but here's what I use *LINK*
I have that same table, and it works quite well. Adding a low profile vise to it also works well. I have several, but this is a good example:
drill press vise
Ditto +
Mine tilts to 45° across the jaws.
Clamps to the table and used for metal work.
