Big O'l Dewalt RAS
Big O'l Dewalt RAS
Big O'l Dewalt RAS
So I know a guy who is selling a 16" 5hp 1ph Dewalt (pictured). I have not inspected it yet but told it's in great working order.
I would consider it for cross cutting large lumber (wide or thick) down to lengths. It crosscuts 26".
So for anyone who knows these saws....how hard are they to keep true?
What are the downsides of these beasts?
$700 a decent price?
TIA
Tom
Re: Big O'l Dewalt RAS
Truest saws ever
Those old DeWalts have a bulletproof registration system with a tapered locking bar that keeps the arm dead-on at 90º. $700 is a fine price. They sell refurbished models for $3K or more, though I have not shopped them lately.
William Duffield
I'd trade in my old 9" DeWalt for that one in a heartbeat, and then I could stop thinking and dreaming about dropping twice as much $ for a Kapex.
Ken Oakley-Sunny St. Cloud, FL
Never met one I didn't love. $700 is pocket change to you Tommy.
Run, Don't Walk
To the ATM, thence to this guy's place before somebody else jumps it.
You people are bad influences!
Does nobody here see my post as a red flag for help? I need an intervention!! Hopefully, if I do decide to go for it, my wife will do the right thing and throw cold water in my face.
Thanks for nuthin! ;-)
Robin Corell in Atascadero CA
Just about every pattern shop I worked in had one of those. its a good saw and can be trued up and adjusted in just about any direction. for cutting at 90 it is hard to beat. if you do a lot of cutting at an angle then a monarch unipoint would suit you better.
I have the 10" version of that saw stashed away in bits and pieces for if I ever get a bigger shop.
Robin
Alan Young
It's your own fault
Alan Young
You shared pictures of that new shop-I saw open floor space-Till that space disappears you are "required to acquire"!
Your friend with no floor space-Alan
Roy
Check out the bearings in the arm to see if they are smooth. See if there is excessive wear in the ways in the arm. Check the bearings to see if they are smooth. Not much else to look for. I have a smaller version, a 14" GA with 3hp and it has served me well. I don't think my electric service in the barn would hold up for a 5hp motor.
Roy
Bearings
Thanks....I'll check them. I know the guy selling it and he just started it up this morning. He states that the start was quick and smooth and the blade spun for minutes after the shut down. I like the sound of that but will confirm in person.
Tom
A.J. Hamler
The Downside:
A.J. Hamler
At your advancing age, that would be the hernia you'll give yourself trying to move it into your shop.
That's why I keep my day job......
....so that I have full medical coverage to cover the injuries I get at my woodworking job! ;-)
Re: That's why I keep my day job......
TomD
I would have thought 2-300. But it is whatever the local market dictates, which is rarely cheaper where I live. Around here you can't give old saws away, and the bigger they are the more that is true. All the small shops are closing down.
Re: Bearings
TomD
Take a dial and test indicator and indicate the arbour in several axis. You can also feel for the play, which is pretty accurate in certain situations.
Sad but true.
I have benefitted this year from shop closures and downsizing. It is nice to get great tools for a bargain but I do so with respect for the sellers. It is not easy for them. If the deal is good enough I won't twist their arm any further....they have suffered enough.
Better for the tools to go to appreciative woodworkers than to scrap metal salvagers I guess.
Can you elaborate?
Gary Smyth
I see these not often but several times a year. They are priced about what Tom posted. I don't have use for the DeWalt honker but I'm interested in how the 90 degrees is "locked in".
I don't have that brand, but mine
Keith Newton
will cut off 30", which is nice. I wouldn't want one with less than 24" capacity.
I have used one of these before, and unless something is broken, you should't have anything to worry about. I only gave $400 for mine, which is 3 phase.
The only downside that I can think of, is to really be their best, they need to be against a wall, with at least 12' off each end in the clear, or 24' dedicated to it.
Then make a long table, with a fence that you can make a lockdown stop with an index for the ruler. Then NEVER move it off 90º.
It is easier to make those odd angle cuts another way, than running this top.
Also, don't ever put a blade on there with more than 5º hook. But I'm sure you already knew that.
Re: Can you elaborate?
There is a steel ring at the top of the column with tapered slots machined at multiples of 90 and 45 degrees, and a tapered bar that pivots into whichever slot you want to provide a positive detent precisely at that setting.
Got it.  I'll look for it.  Thanks
You may be right (as usual)
I would have gladly spent $700 in the old days for this saw, especially since it's single phase, but noweadays you might find the same saw for less. It better be local, though, 'cause shipping would be a major issue.
Re: You may be right (as usual)
The plant I worked in had one in the maintenance shop - it was probably 25 years old when I started. It was dead accurate, even though it was abused and misused often. It was still perfect when I left almost 40 years later - think they may have replaced the start switch, a half dozen tops and 10 or 20 blades during that time!
Found one.  Big, 3/4" thick.  Nice.
