REAL MILK PAINT
epoxy and sawdust mixing
Joseph Mulherin, sr
I have my first chair mostly assembled, but there are some saw cuts which I wish to address by mixing up 5 minute epoxy to fill in with sawdust from the wood cuttings. Question.... do I mix the sawdust with the resin first to get the consistency of the putty like mixture then add the hardener to get the epoxy started working??? Never worked with epoxy in this fashion....just made a canoe many years ago which I fiberglassed....17footer.
Re: epoxy and sawdust mixing
Dave Paine
With the 5 min epoxy, I agree with the approach of mixing the sawdust and resin first. This way you have not started the reaction.
Gives you more time to adjust the amount of sawdust.
The only nuance with the 5 min epoxy is that the hardener is 1 : 1 volume with the resin, so it may lighten the mix.
The alternate is to use e.g., 30 min epoxy then you will have more time to mix, start the reaction and then blend in the sawdust to get the shade you need.
David Barnett
(Message Deleted by Poster)
Suggestion
Ditch the 5-minute stuff, it's fine for quick repair of nick-knaks, but IMO, it's worthless for wood applications. West or System Three are far superior although you have to be precise in the mixing. With those, you mix resin and hardener, then add your wood dust to adjust the viscosity you want.
A note on wood dust. Use a fine screen kitchen sieve to separate out large pieces; what works best will be a fine powder. I get mine from the filter in the shop vac that I use hooked to the sanders.
Re: I've had problems with 5-minute epoxy...
Joseph Mulherin, sr
Thank you, Davids, it looks like I should shop around to find the 30 minute epoxy. I bought the 5 minute 4oz bolltles at HD as it was all they had except for the tubes.
Am glad to hear that my thinking is correct in the mixing of the sawdust. I want to get this process correct for when I continue building my next 6 chairs for my family members to have something i have made for them.
Re: Suggestion
Joseph Mulherin, sr
Yes, Mark, that is exactly where I get my sawdust for this process. Of course larger gaps can use the other cuttings, but I shall be using nothing but the sander dust for the mixings.
David Barnett
Re: That works well
Joseph Mulherin, sr
Yes, Dave, that is what I have saved ...also the cuttings from my chop
saw when needed. I just ordered the epoxy putty from Jamestown Distributors.
Shall mix in the sawdust if it does not meet my color satisfaction, but they say it dries clear and is sandable.
Should mix in real nice on my chairs....shall at least give it a try to see how this product comes out and shall post results. I shall try to post a picture of the finished chair in a few days.
David Barnett
craigd
Re: 30-minute epoxy...
craigd
I got my 30 minute epoxy from the local hobby store*, $10 for two nine oz bottles, which is taking me years to use up.
* I have no idea who makes it, it is a relabeled Bob Smith product, who knows where they get it.
Re: Eager to see your results
Joseph Mulherin, sr
Hi, David, OK, I have the seat contoured like Charles Neil shows on his You Tube program.Still have to sand off the front and all around the edges. Installed the legs fore and aft, glued up real nice and level. Have the rockers and laminations which go underneath the legs to screw to the legs and epoxy to the rockers. Arms are cut and ready for contour sanding where the arms rest in them Back braces have been made for awhile; cut them to length and am ready to install next week. LOTS of routing and sanding to do from now on.
I am not sure I will be able to post a picture because I have a problem with the resizing programs which I really do not understand. The lowest I have been able to get is 376mg and that is too large for WC.
Its for RC airplanes...
John in NM
Better hardware stores, when you can find them, sometimes carry it too, but in small tubes.
I also use PC-11 epoxy (from the better hardware stores :D ) mixed with transtint dye for color. But I'm usually filling little knots and things, might not look ok on a joint.
Bob
Bob
It looks like you have a lot of answers to chose from and all are more informed than I am never having worked with any epoxy I have been looking and doing some research and I like the sound of the westsystem's products link here= http://www.westsystem.com/ss/ I watched a video Mark Spagnolo (wood whisperer) made where he introduced it and they have good video instructions as well as customer service to talk to. I would like to know if anyone here has used it and if they recommend its use?
David Barnett
Re: I mentioned it in my reply...
Joseph Mulherin, sr
Thanks, David, I bookmarked the website for future use. The videos are very informative too.
Re: epoxy mixing
When mixing small batches of epoxy (under 4 oz of resin) it can be difficult to get the proportion of resin to hardener correct. This can lead to poor performance and a mess of half cured, gummy resin to remove from the project.
I use System Three (the other large retail marketer) which is a "2-to-1" ratio mix of resin to hardener. As I'm always mixing less than 2 oz. I bought a digital gram scale ($16 - Amazon) that makes it easy to get the exact 100-to-44 parts by weight ratio that System Three directs.
West recommends using their "metered" pumps to dispense the product for mixing. I've not tried them.
Pumps work fine
Ray - Middletown, in
but you do need a scale for very small batches. The pumps dispense to much for most small projects, but they are not thinking of the small batches we need most times. I also like their 404 filler, seems expensive but lasts a long time.
Ray
The thing about a scale...
John in NM
You may need two.... first one I bought for mixing urethane resins got confiscated by my wife because it was so useful :D
The pumps do work well though for medium size batches and frequent use. When I worked for a shop that used West System daily, we quickly got the hang of "half shots" when needed. It was handy to have it always there and ready to dispense with the pump.
Re: I mentioned it in my reply... *LINK*
William Duffield
I agree with David's recommendations on Gougeon Brothers' West System epoxies. I usually buy West System at West Marine. The names are only coincidental.
When mixing medium or large batches, I use the pumps. When mixing very small batches, I use graduated, disposable mixing cups, which I get from Lee Valley. (See link at bottom.)
I have found that it is critical to thoroughly mix the hardener and resin BEFORE adding any fillers or colorants (and you don't have time to do that if you are using 5-minute epoxy). If you have a big job and don't want to run your sander all afternoon to get enough sawdust for filling, Gougeon makes an excellent sawdust filler, their 403 microfibers.
http://www.westsystem.com/ss/fillers
They have the best user documentation in the industry, and have done their homework, so you can trust their recommendations.
For coloring, I use vegetable black powder, powdered tempera pigments (which you should be able to find in primary and secondary colors at a good art supply store), and even TransTint dyes. Mixol pigments also work.
You can buy System 3 at Woodcraft. Pumps are also available for System 3, but for some strange reason, Woodcraft doesn't carry them. The graduated mixing cups in the link below also do not work for System 3, which needs to be measured and mixed by weight, not volume. I use a postal scale. There are just too many annoyances with this system, so I almost exclusively use West System resins and hardeners. The System 3 fillers also work with West System resins and hardeners.
A postal scale also works with West System. I use the 206 slow hardener in the summer. It uses a 5:1 ratio by either weight or volume. You need to make a minor adjustment to the by-weight mixing ratio for the 205 fast hardener. Temperatures and mixing ratios are very clearly explained in their documentation.
http://www.leevalley.com/US/wood/page.aspx?p=20009&cat=1,110,42967
Pumps
I use them on my stuff as well.
I put the mixing cup on the scale, zero it, dispense the resin, re-zero it, dispense the exact (within .000g) amount of hardener called for, and I'm good to go to add whatever else I need want.
Re: Pumps
Joseph Mulherin, sr
All of these suggestions are just fine for what I need in my project. And, Mark, I shall try to use the medicine cups to get the proper amt of resin and hardener. Am thinking I shall mix up the Alder sawdust
to a peanut consistency then add the hardener.....should mix up good and be color right.
Another thought....mix up the entire mixtures, place them inside a sandwich bag, clip off the end and just squeeze out what you need where it is needed..... and no mess for a lot of clean-up I think.
David Barnett
Cups
I have a bag of used (recycled-clean) small solo cups like you get with takeout food. I have my buds save theirs for me. Make great mixing cups and I'll usually get 3-4 mixes out of one of them. Moisten a paper towel with DNA before the epoxy gels and the cup wipes out clean; no muss or fuss.
Do NOT add your bulking agent before mixing the hardener; it will be very difficult to get an even and proper mix of resin and catalyst that way and you'll be "asking" for uncured or partially cured epoxy. ALWAYS mix the epoxy first, then put in your addments.
Another pigment
John in NM
I've used Proline in both West System and 5 min epoxies. You can get it at actual paint stores (rather than the Home Despot). It will go into just about anything, though you do have trouble using it with higher temp curing resins like the urethanes.
Re: Fun with pigments
William Duffield
Thanks for the link. Unlike the Sheffield Colors in Oil that I have been using, dry pigments should have an indefinite shelf life. The Earthpigments.com prices (typically $4.63 or less for 100 g.) sure beat Woodcraft's retail prices on Mixol pigments ($5.79 for 20 mL), especially since you are not paying for the carrier (ethylene glycol). I had some lingering concern, but Googled it and found out that ethylene glycol is compatible with epoxy, so the Mixol works fine.
--If you want to find patina, you must first find dirt.
