Progress on Chest of Drawers
Bill Tindall
The sides of this chest of drawers will be a Period correct frame and panel. The attractiveness of frame and panel depends on the frame. It should complement and not detract from the more showy panel. Here I am arranging rails and stiles for best effect.
Next mortises are prepared. I chose to chop them with a chisel made from a piece of tool steel bar stock. I find a hand chopped mortise to be more precise and have smoother sides than a hollow chisel made mortise.
I make tenons in a way that results in reliably crisp joints.
First I scribe the depth of the mortise on all four sides of the rail. Then I saw the thickness of the tenon on the table saw. Note the white poplar spacer piece. It is precisely sized so that when I make the first cut with it in position and the second cut with it removed the result is a tenon of precise thickness to match the mortise.
Next the waste of the tenon is cut away and the tenon depth is precisely chiseled to the base line previously scribed. This approach results in tight fitting joints.
The tenon lengths are marked and waste removed.
Finally, the fitted joint.
