Sawing a large log question
I have been posting about the oak tree that fell on my rental house in a recent storm. Today I eyeballed the small end just below the the first branch by holding a ruler up and trying to judge the top and bottom to be even with the surface of the future log. (tree is not cut up yet) It appears to be 30" or more. I am thinking the other end will be closer to 36 to 40". This would be cut into three or more logs at least 8' long.
I have called a guy with a bandsaw mill who has done some sawing for me before, but he had not called back. I suspect his mill (Woodmizer) will not handle it. So how do I deal with three logs 32" and larger?
Re: Sawing a large log question
Call a guy with a bigger mill. IIRC Wood Mizer has models up to 70" in capacity.
find a sawyer with a swing blade mill
Dick Coers
Like a Lucas or Peterson. They can handle logs way bigger than what you have. Unless of course if you want some huge slabs. Those guys have attachments to add a chainsaw bar on the mill and cut big slabs.
yard tree
Jerry Gibbs
curious if you find somebody who wants to cut up a yard tree.
Robin Corell in Atascadero CA
arboristsite.com has a milling forum and there are guys from all over the country with a variety of mills. A chainsaw mill would do it no problem.
Robin
Keith Newton
Hey Barry, My little Woodmizer LT 15 has 28" across between guides, but I would much rather have a log like yours, than one at that diameter. I like to rip them with a chainsaw, then put the halves on there. I can turn a really big tree into mostly QS, and have some lumber worth getting excited about.
With my old chain-saw, I could rip down a 12' log in about 15 ~ 20 minutes, using a 28" bar. I haven't done this with my new Stihl 391, but it will probably be about the same. So if while you are hunting for someone with a mill, why don't you try to get your hands on a good medium size chainsaw, and i will coach you on how to make the few cuts necessary to get it onto a band-mill. Sure it is hard work, but I enjoy doing it for the adventure. Trust me, it will be worth the effort.
As a side-note, I have just started working with a new customer who had the largest Loblolly Pine in the state. Bugs got in it, so he had it sawn. He said he searched far and wide for someone with a mill large enough to handle it, before taking it to someone with a swing mill as someone above suggested. The widest boards are 12", which makes me a bit sick, when I could have taken care of the sawing, if he had found me. We could have be using 20" edge-grain boards for table and desk tops, instead of 11". He wants his desk to be 36" W, so that means 4 boards for the top, instead of two.
TomD
I personally like to cut pieces fairly thick. I find that they dry straight, and there are more options when it comes to using the stuff, but lets just say you had a 2 in x 42 in x 8 foot piece of wood. Wet that would weight around 250. So while I have the do it yourself chainsaw mill, that size of tree is a fairly large chunk to handle And I like to cut thicker pieces still, and just don't have the gear to work too many pieces that big.
Not a yard tree.....
About thirty years ago I developed this piece of property out of the woods. Bought six acres that had never been built on and heavily wooded with large oak trees. Struggled to find somebody that would l take the trees for the "cost" of removing the stumps. Ended up bulldozing them and giving the wood away. This tree is one that did not get bulldozed and was standing across a little wet weather creek in the woods until a storm came through. Its just getting even for all of its buddies I cut down years ago.
When I mill I am usually by myself and I always mill at 2 1/4" thick and often end up with slabs that I can't lift. I have quite a few slabs that are close to 36" wide! When you mill a slab it leaves a bit of sawdust in between the slab and the log which makes it easier to slide the slab. It is even easier to slide the slab if you turn it 90* to the log. I then position my truck and slide the log into the back without ever actually lifting it.
Unloading is a different story and for that I usually get a couple of neighbors to give me a hand.
Once the slabs are dry I can usually lift them without much problem.
Robin
