What did I do wrong?
Warren White
I am making something which won't be described just in case it all goes in the garbage.... I don't need to mention that this has really frustrated me.
I made a pattern for two different items, stuck to the material to be routed with double sided tape. The was had been cut off to no less than 1/4 inch. One was to be routed on 1 piece of well figured maple; nominally 3/4 inch. The other on two pieces of 3/4 inch figured maple that had been glued together to make nominally 6/4 stock. I have a Hitachi M12V router mounted in an extension on my table saw.
Routed both of the 3/4 just fine. Picked up the first of the 6/4, thought I might increase the speed of the bit a little because of the greater depth of cut. (Using a nice sized pattern bit with a 1/2 inch shank.) Adjusted the height of the bit to just cut the 6/4 stock while following the pattern.
Wham! Took a big chunk out of the wood cutting the end grain! Maybe I was a bit too casual. Picked up the other piece, stuck the pattern on and proceeded more carefully. Wham again, only worse. Both pieces of wood were ruined.
What the heck did I do wrong?
No hurt feeling here, I just want to learn (in case I ever want to try this again....) Nothing on me hurt either, for which I am most grateful.
WW
Re: What did I do wrong?
Lee Schierer McKean, PA
Sometimes when the router bit hits the end grain it will grab the grain and BANG instant tear out. The only cure I know of is to carefully examine the wood before cutting and mark certain areas of grain reversall for climb cutting. When routing in this direction -> you want the grain to be \\\\\\ if you encounter grain going //// then tear out is likely to happen. You need to have a good grip on your router (or work piece if table mounted) when climb cutting and take very shallow cuts on reversed grain.
Lee
A picture would be helpful
Bill Tindall
I don't see how it is possible to tear out end grain, for the wood fibers are well supported by the end grain beside them unless the bit is exiting an edge in which case splitting out the end grain is to be expected.
Robin Corell in Atascadero CA
The problem with routers is that when mistakes happen they happen at 20,000rpm, which makes it hard to see where you went wrong.
It sounds like the error was in introducing the work to the bit on end grain. I have had this problem with similar results. I get better results by introducing the work to the bit on long grain and then working around a corner to the end grain. A routing pin a few inches from the bit might also help.
If there is a way to design your patterns so that you don't need to rout the end grain and register your pattern off that edge you will be way ahead, even if you can eliminate one edge of end grain.
Hope that helps and gad you are OK.
Robin
Warren White
Boy Robin, you have that right! I just barely touched the piece to the bit and it instantly grabbed and tore the piece up. I wasn't trying to take anything off at that point, just trying to get started.
I have always said that a router is a great tool, but it can ruin your work faster than lightning.
I suspect a router pin would have helped, and I confess I didn't use one. I did go from a straight part to the end grain, but nothing seemed to matter.
Thanks for the thoughts. I have glued up some new parts and will just use my spindle sander to get to the finished edge I want. (That and a few hours standing and sanding.)
Carol
Bigger the bite dictates lower RPM's. That and you were unprepared for the force. Be careful climb cutting end grain. End grain is plain grabby. Confident care is required. That and sharp bits. But you knew that.
A starting pin is a MUST for template.
Keith Newton
If this was a pretty tall cutter, you could have even bent the bit or collet when you have a big snag like that.
If this is a piece where you plan to rout all the way around, start in a place where the grain is favorable, then go all the way around from there.
Someone above suggested climb-cutting. I would advise against that, unless you are holding the router, instead of the work.
Warren White
Carol, I think you may have hit the nail on the head. I really should have slowed the router down; I am sure it would have been less prone to grab.
Thanks to all for the responses. I will store them all in my memory (if I can only write from it when the time comes).
Thomas S Stockton
Warren
One thing I would add is that using double stick tape is not my favorite way to attach templates. I prefer to be able to clamp the piece to the template using destaco style clamps.
If the template moves on the piece of wood even a little it can cause problems, plus you can make the template longer to give yourself a starting ramp which serves a similar purpose to a pin you can also add handles or use the clamp handles which gives you a better grip on the piece. This technique requires a bit with a bearing at the bottom and put some sandpaper strips on the template to help keep the wood from moving.
I recently had a leg blow apart template routing, I was tapering a leg taking of about a 1/16 and the bit caught the wood and broke the leg in half. I had only used two clamps on a 33" long leg and the middle of the leg was able to move enough that it caught it shattered the leg. I added a third clamp and all was fine.
Tom
One more thing about Carpet Tape
Keith Newton
They are not all equal. Don't even bother to buy it, if it has a thin plastic film for the core. All that I have ever tried, didn't hold nearly strong enough for this task.
I like the cloth core, but have used a fiberglass core, but don't like it as well.
Then there are some foam core, which stick too good, but have too much wiggle room in that much added flexible height.
Sometimes it is easier and faster to just screw the template to the part, if the holes don't cause a problem.
How big of bite were you taking?
Dick Coers
On figured wood, I cut really close to the pattern. I don't want to take off more than 1/16". I've also had better luck with the Freud 1 1/4" diameter pattern bit over a standard 1/2" diameter bit.
Re: How big of bite were you taking?
Warren White
Where it grabbed, the amount of material to be removed was no more than 1/4 of an inch, more likely around 1/16. The bit had a 1/2 inch shank, and was fairly beefy.
I think that I just had the bit speed too high and my procedure was probably too casual.
Thanks for your insights, though.
WW
Jesse Cloud
I would add +1 to Lee Sheirer's and Tom Stockton's answers. When the bit is spinning the wrong way for the wood grain, it will want to grab and tear out. Climb cutting is an answer if you do it very carefully.
My buddies and I do a lot of template routing and use a few different techniques, depending on personal preference.
1. Tommy's suggestion about a carrier that holds the piece with destaco clamps is golden, make one for each side of the workpiece.
2. There are a few ways to ensure that your bit is always spinning in the correct direction. Both use Lee's technique for marking the correct direction. Then you can:
a. use a shaper with reversible bit direction to solve the problem or
b. use a bit with bearing on top for one direction, then flip your workpiece and use a bit with the bearing on the bottom for the other direction.
c. make 2 templates. leave your workpiece a couple inches long on each side. tape the templates to top and bottom of the workpiece, being careful to align the two templates. Drill a hole through at the extra wood at each end and run a dowel through (trimmed flush) to ensure alignment (and repeatability). Then you can do the process described in (b) with only one bit.
These processes are very safe and will not tear out grain.
Warren White
I would like to thank each of you for responding with excellent instructions for doing the job next time without the danger and damage of my first try.
I sincerely appreciate the help you have given.
Warren
Steve Jenkins
I would suggest that you get a spiral or shear bit. That is all I will use for template routing. the difference between using a spiral and a straight bit has to be experienced to be believed. Also trying to remove 1/4" with a router on end grain is a recipe for disaster. When you rough out your stock cut as close to the line as possible in the areas of end grain.
the absolute best bit I have found for template work with a router is made by Nordic Saw. I have both a top bearing and a bottom bearing.
Most of my template work is done on a shaper now. The cutting geometry of the larger diameter cutters makes things much easier.
Steve Jenkins
"Always use the word impossible with extreme caution"
