knee surgery planned
Joseph Mulherin, Sr.
Went to my VA emergency room on Friday and the doctor suggested I go see the Orthopedic doctor for possible surgery on my left knee. Seems that the miniscus might have to be cleaned out or some ligament damage repaired. So, shall be putting my woodworking aside for a while.
I have the Shopsmith 11"' band saw, and sat and looked at the housing...figured out how to make and add a riser block to it to increase the height of my cuts. Just a wooden block cut on angles to fit the inside of the housing and just screw it to the remaining pieces. Figure on raising the upper blade wheel about 5" to give me at least an 11" cut.
Should work, then figure out the length of blade I shall be using.
Have most of the chair parts cut out on present band saw setup, but have the need to cut the headrest at 8" while forming it.
