Installing prehung doors on steel studs?
A friend is "building out" and office space he bought. They put in steel studs and drywall and are now trying to install prehung doors. He is struggling with trim screws. (When I did this, I put a wooden buck or frame inside the steel studs to line the opening and then drywalled over it. Then I just nailed the jambs in place as if there were wooden studs.)
The question is, how to do this with steel studs? Are there special screws? I would like to help him. Anybody got a trick up their sleeve?
Re: Installing prehung doors on steel studs?
Larry in nw ohio
Barry Yes I believe they have special metal screws for hanging things on ssteel studding. I believe all you would need to do is ask at the box stores or any favorit store. Goood Luck with you hanging. Larry
Screws are "self drilling" with a hardened spade point.
Andy Lincoln,in Dearborn MI
Barry,
Alot of times I will pin the jamb into place with air driven 16 ga. finish nails and then come back and drive in the trim head drywall screws.Many times the force needed to get the screws to pierce the studs and to set the screws properly shifts the jamb alignment.The finish nails help to minimize that.
I totally agree that backing up with a wood stud jamb is the way to go when you have the opportunity.In this case it doesn't sound like an option.
Andy
Keith Newton
Barry, If you can, I would surely try to install some wood cripples and header, which will make it a lot easier to get a good job.
Otherwise, the problem with self-drilling screws, is I'm not sure you can find them with a trim head.
Otherwise, some of what I'm seeing when I install my work in spaces which are already trimmed out, is using liquid nails behind the trim, then a trim gun to hold it in place while the glue sets. This might be fine for hollow doors, but I wouldn't count on it holding a solid slab door.
And on the baseboard, they don't even attempt to hit the studs, just glue and shoot the finish nails through the drywall with some slant.
TomD
In the last office I had an office in, they contact cemented the baseboard in. It must have been built up or something.
