cable drive chuck
cable drive chuck
cable drive chuck
Joseph Mulherin, Sr.
I am seeking to purchase a cable drive chuck which will use to hold my sanders for smoothing out my chairs. Does anyone know what it is called and where I could purchase one? TIA
Re: cable drive chuck
John Luke
Google is your friend.
Just search for flex shaft tools.
Larry in nw ohio
Joe If I understand what you want, Sears has a couple different type that fit on the ends of the small hand held router like the dremel. Matter of fact Dremel may be where to look. Good Luck. Larry
Thank you, guys
Plan to spend a little more
My dad purchased a couple of the cheapest flex shafts he could find - designed to mount on a regular drill - years ago. The shaft tended to "wind up" in use, turning into a pretzel. When you look at the choices, be prepared to go upmarket a bit; avoid his experience.
Re: Plan to spend a little more
Yes, Bill, I understand that can happen. I want the flex cable to run inside a housing to prevent the corkscrewing. Want to attach it to my Shopsmith on the drive shaft, then install various round spindle sanders I have in the chuck so I can smooth the gentle curves on the chairs where the legs meet the seat and smooth out the rockers to a nice looking curvatures.
Am going to go to Sears and see what they have, and also look at the Dremel.
Larry in nw ohio
Joe Sears may also have Dremel. Larry
Tom Dunlap
Maybe these?
http://www.thefabricator.com/article/cs-unitec-inc/flexible-shaft-grinder-designed-for-awkward-pieces-hard-to-reach-areas
http://www1.mscdirect.com/eCommerce/NavigationServlet/Power-Tools/Grinders-Sanders-Finishing-Tools/Grinders/Flexible-Shaft-Grinders-Accessories/Flexible-Shaft-Grinder-Accessories/_/N-77f0r?refinement=4290194438&searchandizedOk=Y
Rick L
Re: Air Cushioned Sander
Rick L
http://www.industrialabrasives.com/sanding-drums-airfilled-cushion-contour-sanders-c-76_204.html
You should look into the air cushioned sander to get nice countour profile sanding. They used to be expensive and are common in industrial shops but now the home shop can afford them.
