ADVERTISE HERE - FREE TRIAL
Commissions part deux
And now for the big boys.....
I was commissioned to do 2 pieces for a client in Charlotte NC. They must have a big dining room. Both of these pieces are huge. In fact, they are generally the largest case pieces I have ever done.
When you have a one man shop, big pieces are more of a challenge. You have to get more resourceful about space utilization, methods of construction and moving the pieces.
First up is a wine cabinet. It is 6'-6" tall, 40" wide and 20" deep. The case and doors are made of curly cherry. The legs are ebonized walnut.
The second piece is a sideboard. It is 8' long, 31" tall and 22" deep. I tried to get away without a middle leg but that span was way too long. So there is a hidden middle leg.
Once again, the case and doors are curly cherry. Both pieces have panels with bird's eye maple, claro walnut, big leaf maple and zebra wood veneers. Dividing the veneers are ebonized "cames".
The sideboard has adjustable shelves and two drawers lined with Pacific silver cloth.
All I can say is that I might seriously consider having a size limit for future work. I ain't getting any younger!! A "white glove" shipper will be picking them up sometime soon. I can't wait to get them outta my shop!
T.
Re: Commissions part deux
Mark Valsi
absolutely stunning work !! Amazing, one of the best projects I have ever seen on the web !! WOW INDEED !!!
Incredible work as always!
Great stuff!
I think
you're gettin' the hang of this woodworking thing.
Keep this up and you're gonna have to hire help. Then it'll be a real business and you get to deal with workman's comp, insurance,401K's . . . . . .
Tasty stuff, Tommy, very tasty, indeed.
(good luck with the white glove dudes)
George Colonel's Workshop-Havertown PA
Those pieces are over the top, Tommy,
My own work looks so infantile as a comparison to yours. That veneer work is simply astounding, as well as the design of both pieces. I sure hope the consignee receives the white glove treatment, because any marr or scratch would be heartbreaking. Very masterful work, as are the two tables shown in the post below.
George
Thanks Colonel,
I did cut a few corners. The backs of each piece are made out of old cardboard. Everything was joined with a hot glue gun. And the finish is nothing but lemon scented Pledge. Even still, I think they came out ok.
T.
That is the way I do all my work too.
Keith Newton
Glad you are up front with us.
That reminds me of an inlay project I did for my Mom back in the seventies. I had inlayed some flowers into a serving platter. Saw my sweet elderly neighbor out sitting in her garden, and thought she would like seeing my Mom's Christmas gift. When she took it into her hands, she gasp with excitement, Oh, I do decoupage too!
Keeping that in mind, you could probably save a lot on that parquetry by switching to the vinyl wood-grain shelf paper. he he.
Nice work.
Mighty fine
I knew you had it in you, Tommy. :)
Can you describe the process of assembling the parquetry?
Gorgeous work.
Re: Mighty fine
Thanks Ellis,
This process is not parquetry per se. All of the black lines are strips of ebonized wood that are proud of the veneer. It creates an effect like the cames in a stained glass window. How I do it:
- Lay out my design for the panels at full scale.
- Create templates for each area of veneer.
- Use the templates to mark the veneer and cut out the veneer pieces.
- Glue and vacuum press each panel.
- Use a guide jig (I make that) and route 3/16" dadoes to recieve the cames.
- The cames are 1/8" thick strips of walnut that are 5/16" wide. I cut 1/16" rabbets on each side to fit down into the dadoes. They overlap the veneer pieces allowing a clean look.
- I ebonize and finish strips of came. I also sand and pre-finish the veneer panels.
- I assemble the doors with the panels. Each panel is 3/8" wider on all sides to fit into dadoes in the rails and stiles.
- I then make a jig for my miter saw to hold the cames as I cut them exactly to length to fit the various dadoes around each veneer area.
- I then glue all the came pieces in place.
That's how I do it. Yes, it's a laborious process but the results are quite nice.
Is that the buffet with wipe on poly?
Dick Coers
How did you end up fixing the sheen issue you had on the top? Nice work.
Yes...but not fixed yet!
Thanks but the photo is decieving. In raking light you can see the areas of uneven sheen. I am creating a test panel of the same wood and poly in order to try different methods to see what works best before I work on the actual top.
BTW- Wipe on Poly....never again! I just bought an HVLP so I'm going that direction.
HC Sakman
Nice work Tommy.
Chico
Second thought...
HC Sakman
I would love to see the insides of both pieces. Open up Tommy! ;-)
Chico...
Sophie
Beautiful work Tommy! Makes me wonder what I've missed of yours since I've been away?
Sophie, on the move in Wyoming
Robin Corell in Atascadero CA
Nice work tom, A nice christening of the new shop.
I know what you mean about large work. I have one coming up and I don't know what is going to be more challanging the the size of it or the actual construction. Almost makes you wish you were a jewler dosent it?
Robin
